Hi a read 93c46 from gsx750f, which odometer locked on 99 999km. i need correct eeprom to show around 5000km or count from start 0. thanks for very much. EEPROM readed with carprog using A4 adapter.
04498 on the dash... thanks a lot a lotyou are ace.
sony_2006 (10th March, 2019)
I have a 2003 GSX 750 F with 93c46 and 99999 km on the odo. I want to find out how the mileage is saved in eeprom, so I can fix mine.
I was going to compare these two files but I cannot download MiraMT's zip file. And from the 4498/5000 file I could not found a hex representation of 4498 or 5000. What is the correct procedure for writing a specific mileage to the 93c46?
I believe the 93c46 does not have anything vehicle-specific, so I could just flash the 5000 to mine, too. But I'm only at about 101000 km, so I don't want to flash 5000 but the correct mileage instead.
Any info is appreciated!
Not my department but think you will find check sum error
OFF TOPIC:-
do on here search for rover 75 same issues, caused by check sum
ON TOPIC
As you know the mileage of abouve dump, enter into google decimal to hex
and see it repeated in the dump normally
As stated before, this could be check sum error.
You wount find decimal number in hex, it’s encoded using curtain algoritms, so you have to know what are you looking for. I always start with looking for repeating characters and bits. Almost everytime its 3 times same bits, but some algos have variations. Then tou apply math to it and try to decode
If I helped you, feel free to drop me that sweet sweet +1 thank you.
Sorry, may you help me ?
How many posts may i have to get this file, please ? Sorry...![]()
Suzuki GSXF 750 - 93c46
The mileage is stored in the next lines
1000km = 004E - is a mileagewhere the next bytes:
Olivares (14th May, 2020)
Download them:
original: https://www.mediafire.com/file/sdhs7...%EDky.zip/file
Edited: https://www.mediafire.com/file/j0int..._5000.rar/file
40000km = 0C35
