Results 1 to 12 of 12
    Mar 2019
    Post Renault Traffic Kess Problem
    Hello, I have a Kess V2 clone. normal time I can read and write without problem but yesterday when I reading Renault Traffic 2.0 DCI get %100 and after give me a error message. I controlled the file is correct but gave error. How can I solve the problem ? and my kess is can read and write this type ecu via obd or cant ?
    car inf:
    Renault Trafic 2014 year 2.0 DCI Bosch EDC17C42
    HW: 1754R
    SW: 1037545242
    VIN nr.:
    SW ver.: 3316R
    Spare:
    Engine:
    HW Ver.:
    SW upg.: 5661R
    May 2018
    Fault pic?
    You send an image from Bosch BMW ECU.
    Gesendet von meinem SNE-LX1 mit Tapatalk
    Mar 2019
    Quote Originally Posted by Hexer84 View Post
    Fault pic?
    Awhh sorry this is my mistake I will upload right pic.
    Apr 2011
    Fault pic shows only ecu photo
    you should post fault picture
    Mar 2019
    Quote Originally Posted by crank54 View Post
    fixed please look again
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    And you did this obd!!!
    This needs doing on bench
  7. The Following User Says Thank You to teerak2uk For This Useful Post:
    Meat-Head (18th March, 2019)
    Mar 2019
    Quote Originally Posted by teerak2uk View Post
    So am I have to use k-line? Is it impossible via obd ?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mrspls View Post
    Bench it boot mode with ktag is safer I think some people say they managed by obd but must save injector codes first because sometimes when writing modded file back they get lost
    Try can or Kline see which works but go into tools menu for injector codes
  10. The Following User Says Thank You to teerak2uk For This Useful Post:
  11. #9
    Mar 2019
    Thank you mate, I will try it with kess v2 via boot mode. But I newer see injector code backup menu in ksuite with Renault Trafic. I will search that.
  12. #10
    May 2018
    U have to use ktag not kess.
  13. #11
    Mar 2019
    Thank you friend, Im upset
  14. #12
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    It will be under tools but not required if doing boot mode
