Results 1 to 5 of 5
    rob h's Avatar
    May 2011
    Default Ford bcm by vin partnumber, or replacement partnumbers.
    Hello guys,
    I am having trouble finding a replacement bcm for a Ford Transit 2012.
    Online, by vin, i could only find this number: 1904986
    The labels on these, do have numbers like these: BK2T-14B476-BT and
    A2C53348839M.
    How can i find the correct part, by vin?
    And are there more then 1 possibilities?
    How will i know, what is compatible?
    I am new to Ford systems, and finding the exact part replacement number can be very difficult.
    So any pointers, does and donts,
    Thanks guys
    outer hebrides
    Hi rob
    The last letters superseed previous part no. eg BS BT BU.
    https://www.google.com/search?client...BK2T-14B476-BT
  3. The Following User Says Thank You to scotlock For This Useful Post:
    rob h (21st March, 2019)
    rob h's Avatar
    May 2011
    Thank you, that is easy then!
    And do you know were i can find partnumbers, by vin?
    outer hebrides
    Try here for parts by vin
    https://parts.ford.com/en.html
  6. The Following User Says Thank You to scotlock For This Useful Post:
    rob h's Avatar
    May 2011
    Thank you,
    I tried this site, it does not work with my vin.
    And creating a car, is also limited.
    I found a website, that could id my car by vin.
    It gave me theses numbers:
    12A650 1819788 ecu
    14A099 1849892 bcm
    These numbers, how theses translate to the labels on these parts?
    The problem i had whas this:
    I tried replacing a faulty bcm, and U2101 incompatible came up with the replacement bcm hooked up.
    So i flashed the original, and it came to life.
    Job solved, but question remains, why did i get this U2101 incompatible?
    Or is this a standard thing, if a module is not written with the correct software, or onfiguration, or matched to this car?
    I did program the 2 key in the bcm at this point, but not yet adopted the bcm to the car.
