Results 1 to 15 of 23
    Oct 2016
    Scotland
    Default 2014 ford Transit Custom key programming
    What tools are good for programming a new key on 2014 Transit custom.
    Seems all the tools i've tried fail or get comms error.
    Is there a distinction between the regular transit and the transit custom programming?
    p1et's Avatar
    Oct 2013
    Yesterday did 2014 normal Transit (same as custom) with MVP in 1 minute.
  3. The Following User Says Thank You to p1et For This Useful Post:
    WRX 14 (22nd March, 2019)
    super jumbe's Avatar
    Livingstone
    The cheapy tool you can buy and you don’t need in code and out code is truecode.
    FTC5 Software Update (Ford)
    Transit Connect 14-16 (Bladed)
    Transit Mk8 2013 - May 2016
    Transit Custom 2013 - May 2016
  5. The Following 3 Users Say Thank You to super jumbe For This Useful Post:
    godfathertre (21st October, 2019), Meat-Head (22nd October, 2019), WRX 14 (22nd March, 2019)
  6. #4
    Feb 2018
    Glasgow area
    I've done blue remote transits with Skp-900.
    Oct 2016
    Scotland
    Quote Originally Posted by PixelsFixed View Post
    Blue remote no problem, but this has the new style flip out key and SKP-900 always give me comms error
  8. #6
    Mar 2018
    UK
    What is the remote program on these - just had one I tried 8 times cycling with open door without open door and any other configuration without success
    no sound no central looking cycling
    The original remote doesnt work - no signal
  9. #7
    Oct 2018
    Northern Ireland
    TDB1000 2 mins
    Remote programs at same time as transponder
  10. #8
    Mar 2018
    UK
    Quote Originally Posted by Jimmy07 View Post
    TDB1000 2 mins
    This is Transit VIII 2014 with black remote key not VII with blue key
  11. #9
    Oct 2018
    Northern Ireland
    Yes I know TDB 1000 does them done a 2015 Custom 2 days ago
    I use SKP900 on blue keys and TDB1000 on newer Ford Transits the black teardrop type remote
    Ford Transit Custom 9/2012 – 2016
    Ford Transit / Transit Custom 3 Button Remote Control Flip Key ID63 T17 80Bit
    Transponder: ID63 T17 80Bit
    Buttons: 3 Buttons (Lock, Unlock and Boot Button)
    Frequency: 433Mhz
    Battery: CR2032
    Blade: HU101 Blade
  12. The Following User Says Thank You to Jimmy07 For This Useful Post:
    Manta1600 (19th October, 2019)
  13. #10
    Nov 2018
    Truecode very fast on these upto 2016. Takes seconds. Voltage is very critical. Need boost pack or external power supply to guarantee to connect/program. What are people using token free on later customs and other later fords that truecode doesn’t cover ?
  14. #11
    Mar 2018
    UK
    Quote Originally Posted by autocarkey View Post
    Truecode for key programming or for remote programming?
  15. #12
    Nov 2018
    On the transit custom the board has combined immo/remote so both are programmed diagnostically are the same time.
  16. The Following User Says Thank You to autocarkey For This Useful Post:
    Manta1600 (21st October, 2019)
  17. #13
    Dec 2010
    Nottingham
    truecode , TDB1000 , MVP pro , Smart pro , all are very very good on this year of transit custom .
    for later models smart pro and mvp pro are excellent though use tokens , token free software that will do these looks to be the new ecuworks ford software that you need a pass through device like avdi , xtool etc to use the software and it claims to do all models up to 2020
  18. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  19. #14
    sdnatlst's Avatar
    Aug 2011
    England
    I'm sure there is manual remote procedure for custom 2013 to 2016 using 4d chip.
    I know genuine is integrated TP. But it's also the case for new focus and that can use manual remote and TP, where genuine key is TP in circuit.
    Key case is same too.
    Never tried it myself
    Tools owned -
  20. #15
    rm23's Avatar
    UK
    remote will program itself with immo...
