Results 1 to 7 of 7
    tazz75's Avatar
    Nov 2018
    Default Pinout dash Ford Focus 2009
    Hy..can anybody help with this pinout for bench testing ?!...thx in advance !
  2. The Following User Says Thank You to tazz75 For This Useful Post:
    Suleym (23rd November, 2022)
  3. #2
    Jul 2017
  4. The Following 5 Users Say Thank You to manuel555 For This Useful Post:
    asto (1st June, 2022), rossb83 (21st June, 2023), simon92 (2nd February, 2021), Steve182 (16th December, 2019), Willinickersen (31st March, 2024)
  5. #3
    tazz75's Avatar
    Nov 2018
    Quote Originally Posted by manuel555 View Post
    Thx...found it and test is this too :
    • Pin 06 = Mass
    • Pin 04 = 12v Vcontact
    • Pin 09 = Cluster lighting
    • Pin 17 = CAN(1)-L (500kbps)
    • Pin 18 = CAN(1)-H (500kbps)
    • Pin 22 = CAN(1)-L (125kbps)
    • Pin 23 = CAN(1)-H (125kbps)
    • Pin 32 = 12v Vbatt
  6. The Following 5 Users Say Thank You to tazz75 For This Useful Post:
    asto (1st June, 2022), EDENAUTOKEYS (18th March, 2025), rossb83 (21st June, 2023), Willinickersen (31st March, 2024)
  7. #4
    Mar 2019
    Quote Originally Posted by tazz75 View Post
    • Pin 06 = Mass
    Has anyone all the 32 pins diagram?
  8. #5
    Jun 2019
    Budapest
    @tazz75 cannot send you PM, because it is disabled
  9. #6
    Nov 2022
    Merci pour le pinout dash it works perfectly
  10. #7
    Jul 2024
    Thank you, you were of much help, PINS 17 & 18 work on my cluster. Do you maybe know which pins on cluster is for the transponder key ring antenna ? I want to sync engine ECU with cluster on bench and also need advise if CAN/L & CAN/H from ECU also connect to same line as cluster PIN 17 and 18 ?
