Results 1 to 1 of 1
    slavax's Avatar
    Sep 2016
    Soyuz 1
    Default 2014 FORD ESCAPE U3000:4A "Control Module" Error Fix
    I recently had a problem with 2014 Ford Escape SRS module with U3000:4A.
    Problem: Car came in after body shop work for module reset. After initial reset, the crash data was erased but U3000 showed up.
    Root cause: After searching this forum I tried to disconnect seat belts but nothing. Later I disconnected EVERYTHING. All air bags and sensors.
    Action: The problem was the ODS sensor. When I disconnected the Passenger seat the U3000 went away. The body shop installed a seat from a different year, I thought. Re-ordered a seat for 2014 Escape but they brought a seat with the same part number ODS. Called them again and ordered the seat for 2015 Escape. The seat showed up with different ODS but same harness. When I installed it the U3000 went away.
    Solution: Disconnect ODS sensor if you have U3000:4A error (“Control Module”) If error disappears replace the passenger seat with a correct seat or year above/past.
    Cheers mates!
  2. The Following 12 Users Say Thank You to slavax For This Useful Post:
    ateyourv8 (24th March, 2019), bodziob (23rd April, 2023), dragon100 (23rd March, 2019), Eviltuner (15th April, 2020), hai82der (13th January, 2021), llanesluna (7th November, 2019), nap1222 (22nd November, 2019), pedjica (23rd March, 2019), ruffles1986 (13th January, 2023), sepiv (12th December, 2019), Skpl98 (13th June, 2022)
