Fiesta 2009 hu101
Cilinder ignition wont turn anymore.
How can i remove this ignition lock.
Should i drill a hole somewhere?
I also want to take it apart, and try to fix it, so nothing to destructive.
Thankfull for any help,
Greetings, Guys
Fiesta 2009 hu101
Greetings, Guys
fred77 (23rd September, 2023)
you tried to lishi it?
have you figured out why it isnt turning anymore?
stuck wafer?
worn out wafers?
worn out key?
broken wafer?
pick and dissassemble
https://www.youtube.com/watch?v=38_c6AfQQH4
The thanks button is HERE looks like this --->>>
THANKS
The key whas worn down.
Inserted key, needed jiggling.
New cut key, condor.
Worked poorly.
Cut one more key.
Compensated +0.3 mm.
Worked slightly better.
Then tried org key, nothing
No turning possible with any key.
I think for this one need drill hole in ignition housing to be able to push release pin while cylinder is turned to 1st or 2nd position. But I don't know if this is possible to do in car to drill there and remove just cylinder. Take a look at the video above, mark 3:20-3:24 and you will see where push pin is located, then go see in car of there is enough place for drill a hole.
rob h (27th March, 2019)
Fiesta HU101.rar
Job done,
I bought a used lock, took it apart, and rekeyed it.
I took some pictures, hope it comes in handy for someone.
Still need to take the org apart, to see what is wrong.
There a 10 cuts on the key, and wafers 1-8 are inside the ign.
Thanks guys
Hello guys,
I need urgent assistance to reasemble this ignition lock. I completely don't understand this one. I remember I was dismantling this and also struggled to put it back like 5 years ago but somehow I managed to do it. Now even with @rob instructions I can't...
No. 1 picture: long and big spring comes first to the steering lock metal piece (the sprocket is unable to rotate)
No. 2 picture the first piece comes on spring, need to rotate it to sit properly and then put 2nd piece on top
No. 3 picture: while pushing down both pieces, I put phillips screw.
So all is put together but I can't turn it with screwdriver. The sprocket is stuck, unable to rotate. I don't understand your instruction 1st step: Align sprocket. I can't even move this so what should I do? Please help.
Meanwhile I found a video where some guy is showing how to remove ignition cylinder without unscrewing those 2 phillips:
https://www.youtube.com/watch?v=9rXYagZEDQA&t=40s
But it is too late for me, I have disassembled lock with new (second hand) cylinder so need to put it back to original housing but I can't.
How to align sprocket? This piece can't rotate, I don't understand this. I also tried by removing electric switch from the back and then I hold metal piece which comes to electric switch with pilers and try to turn, it's stuck. WTF???
Even the new, Ford's have this problem.
Heard about 6 year old Connect, a while back.
Could be smart to have a couple complete, ready in stock.
And just rekey, when they occur.
Ok I figured it out how to reassemble everything and will uodste this thread later with Pictures. Its not the end... I have other problem now when trying to rekey this lock for origonal customer cuta. And what is happening is unbelievable. Pics also later as im trying to focus now on how to not get crazy
Ok so to rotate and align sprocket, you must remove electric switch from the back and push that white piece marked in red.
Ok but then I have another problem which is some real mystery.
I started rekeying and pop out the 1st wafer ftom the key shoulder, put corresponding wafer to customers key and it didnt fit. There should be 14 wafer, it didnt git.
Edit:
Musti I tried with every wafer, I have complete set 10 pieces, all from 1-5 and all from 11 to 15 and none wafer fits so aftermarket wafers are piece of shit
Ok so conclusion is aftermarket wafers which I bought is pure sh1t. I put the original wafers which I found can corresond with customer's key and they fit perfect. But I dont have stock original, cant install it with 4 wafers out of 8, grrr
Yes fake wafers doesnt allign with key properly. Here are photos. Not are all stamped.
Edit:
Ok so some numbers fit correctly but '14' which suppose to be first doesnt fit completely. All those '1x' are bad, the ones with one digit '1', '2' etc fit correct. What a headache
Weasel3 (24th September, 2023)
