Hello Friends, can anyone tell me how can I solve this problem to my car?
Hard start
Memory Error:
P0340 Camshaft position sensor
I changed sensor but the error is not eliminated
Thank You
Hard start
Memory Error:
Thank You
You must check timing, then look at the wiring and load test it.
wiring check, is ok, how load test ?
and how to check synchronization?
Check live data, compare crank & cam readings ! Problem has to be Cam sensor , Timing , Wiring or Ecu !
napster02 (2nd April, 2019)
sensor was replaced,
ecu was replaced
what program and under what name to read this data live?
You really need to check wiring from CAM to ECU then if that's ok, check timing or scope CAM v CKP waveforms at the ECU. CAM sensor should have GND, 5v and signal out.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
Wirings is ok,
sorry, I'm a beginner
How program check timing ?
You need check camshaft belt in good state . P0340 Camshaft position sensor generally is for not sinchronize between Camshaft position sensor and CKP sensor. You engine is Out of point.
The belt has already been checked many times and is well positioned
Disconnect plug from ecu and sensor. Rig up a 12v bulb. Run 12v through each wire and it will light the bulb bright, if not, that wire has green rot.
I checked the cables with a light bulb, all are ok
The only thing left to do is get somone with scope. Then you see what ecu is seeing
The information sent is to see with a scopemeter.
On sensors,if do not have scope i use a LED probe to not send wrong signal to ecu.
Like members said could be timing problem (camm,fuel pump,...).
Timing belt was changed before hard start problem?
