Results 1 to 5 of 5
    Default Polo 1.4tdi immo off
    Hi ,
    please help with immo off for this car
    VW polo 1.4 tdi 2008
    Bosch 0281013010
    045906013 E
    EDC 17U01 read with ktag
    I try with immoff17 but program say - not find immo data in this file
    thank you
    Jun 2013
    Lithuania
    Try and report, immo off only in MPC file
  3. The Following User Says Thank You to Milicija For This Useful Post:
    nesmark (31st March, 2019)
    Hi ,
    The car start and working,but glow plug light and immo light is flashing.Can this resolve?
    Jun 2013
    Lithuania
    Quote Originally Posted by nesmark View Post
    Hi ,
    Hmmm, what fault codes P you have in error memory (if you have any)? I don't have another solution, but for immo light, you can just put some electric tape behinde the LED (put in the groove behinde the face or remove the LED), for the glow plug light, what fault codes are stored in memory?
    error is P1570 "engine blocked by imobiliser system",but the car work normaly.I try to clear but after start the car again come on.
    Can you find pin code from eprom or Flash?
    I find pin from dash dump,but when i try to login in Ecu i have error code.from dash i find 04395 and i test in immo system and hi is true.
