Page 1 of 4 1234 LastLast
Results 1 to 15 of 53
    Mar 2019
    Default kess v2 2.47 clone reading problem
    i have a kess v2.47 5.017 clone and i try read my car which renault clio 4 1.5 dci but after finish reading give checksum error and shutdown program. can u help me for this reason?
    i install c++ 2005/2008/2010, netframe work and try on windows xp 32 and windows 8 32
    mancioks's Avatar
    Feb 2017
    Germany
    Possible that your car is already moded. Try search for Ksuite cks off executable, then it will be readed with no cks. Or try other tool.
    If i helped, don't forget push thanks + rep
  3. The Following User Says Thank You to mancioks For This Useful Post:
    phantom20 (1st April, 2019)
    May 2014
    LIthuania
    Quote Originally Posted by phantom20 View Post
    I think you have edc17c42 so it is very brave read this ecu trough obd port with china kess. First of all make boot read with ktag full backup . good luck .
    carmageddon's Avatar
    Italy
    Quote Originally Posted by tiugrikas View Post
    i did many of this edc17c42 with kess 4.036 and kess 5.017 without any problem...power supply connected to the car for 13v
    Jan 2019
    Best Country of the world, GR
    Is it possible to disable the automatic checksum of kess?
    Italy
    disable checksum no...but i think that you can move away the dll's from his folder and check if the software start and work doing ID and reading on a car to test
    Jan 2019
    is this also applies to the write?
    Jan 2019
    In a nearby forum "mhh", there is available a guide of disable chk...
    Can anyone tell us how exactly this deactivation is done?
  10. The Following User Says Thank You to gas43 For This Useful Post:
    robertoschild (20th October, 2022)
  11. #9
    mancioks's Avatar
    Feb 2017
    Germany
    Make backup of your actual ksuite.exe before using this.
    Just can rename it before. Tested working
    Pass=rep+thnks
  12. The Following 28 Users Say Thank You to mancioks For This Useful Post:
    blazej1200 (4th April, 2019), bobthebuilder20 (17th September, 2023), boringbob (30th October, 2019), crazylou2017 (15th June, 2019), dema2 (31st August, 2022), deneme1 (1st July, 2019), excalibur200179 (19th August, 2019), gas43 (3rd April, 2019), george913 (1st December, 2019), harveystewart (26th August, 2022), Jozua (13th April, 2019), Liuzou (5th June, 2024), mariantv (18th September, 2022), mart123 (18th January, 2020), marwan26 (4th June, 2023), Maufrits (14th November, 2020), moky (4th April, 2019), MResat66 (24th January, 2024), ombre57 (12th September, 2021), phantom20 (4th April, 2019), Quilem (19th May, 2019), robertoschild (20th October, 2022), seblis0 (7th September, 2022), Solarisis (4th August, 2019), systemlinux (21st August, 2019), xxxx92 (7th January, 2020)
  13. #10
    Jan 2019
    Pass please! Thank you!
  14. #11
    Jan 2019
    Is it work realy without problem? for example if cs corrected by winols and then write file without calculate from kess? right?
  15. #12
    mancioks's Avatar
    Feb 2017
    Germany
    Yes it works like this. You didnt push rep button
  16. #13
    Mar 2019
    Yes i have edc17c42. How does it solve ? Only ktag? Am i try write without checksum? This way is solve it?
  17. #14
    mancioks's Avatar
    Feb 2017
    Germany
    You can try read with checksum off in kess, sometimes it helpes.
  18. #15
    Mar 2019
    İ will try it. if it is ok i try to write mod file ? Am i have a problem?
