Page 91 of 98 FirstFirst ... 41818687888990919293949596 ... LastLast
Results 1,351 to 1,365 of 1463
  1. #1351
    Nov 2016
    Hello, can someone please help me, I have tried to replace the faulty transistor, but still faced with the same problem P1631 P1651. I cannot solder the new transistor to old area, the solder will not stick, I have tried many different combinations of solder and flux always the same problem, please can someone help me with the solder and flux?
  2. #1352
    What transistor, what pump number, pump connection pictures
  3. #1353
    Oct 2016
    Good day to all! I have some questions: Can somebody answer about PSG5 5E error reasons more concretley? That wrong or happens?
    I have eps 815 and vpm 844. I dont understand the reasons when this error appears. Some times it single, some times
    comes with other erors? for example 59 bip or 55 fuel temp sensor. Its easy deleted and pump can compleate all tests, but
    after all test ends - it appears again.
    another question - anybody know about fuel temperature sensor in left corner of PCB (Model, type, number or any information). I have PSG5 with died temp
    sensor and i want to change it.
    Interest what element on board drives timer control valve?
  4. #1354
    May 2018
    Hello, firned of mine asked if i could help him with PSG5 module.
    5V stabilizer works fine, mosfet tested with DMM seems OK, but im worried about two bubbles on the corners, did the chip unsoldered itself?
    RPM sensor is fine
    Picture: http://imgur.com/gallery/Qg00jCO
    Any other things to look for?
    Thanks in advance
  5. #1355
    Mar 2013
    You can try to pull up transistor very gently with tweezers or with toothpick underneath ,if it lifts you are lucky ,it is easiest repair on this pump
  6. #1356
    May 2018
    https://imgur.com/gallery/dJuUnwZ
    Yep, it unsoldered. photos under microscope in gallery.
  7. #1357
    Oct 2017
    Quote Originally Posted by molnarp View Post
    Hi Guys!
    What is this component?Attachment 673668
    Could you fix it?
    Does anyone else know how to replace this transistor?
    Thank you.
  8. #1358
    Nov 2019
    Vp44 psg5 after replaced mosfet P1608 watchdog error
    replaced 5V voltage regulator but after 1min voltage drops from 5V to 2.5V and l7805 regulator is very hot
    no voltage at mosfet pins also
    any idea what to check now? Any schematic diagram for this module?
    somebody know what kind of element is this on attachment picture? Transistor or diode? Both wires are shorted to gnd
  9. #1359
    Aug 2018
    East Pole
    Mosfet. Questiin: between 7805 gnd and 5v output is a short-circuit?
  10. #1360
    Nov 2019
    no friend short circuit is between 2 pins of this (for me) unknown element near irlr2905 mosfet (inside purple circle on first picture)
    output voltage from 7805 regulator drops after 10-20 seconds from 5V to 1.5V and regulator become very hot
    i cannot detect any voltage (0.2V) on irlr2905 gate mosfet pin
  11. #1361
    Nov 2019
    problem finally found
    IC near regulator coused voltage drop becouse i accidently shorted and cut off few wires with which IC is connected to board pins (wires are very tiny and soft)
    i will never again repair this without microscope
    i hope i will be able to solder pins and maybe IC survived
  12. #1362
    Jul 2019
    Hello there, i need your opinion because i've one opel Frontera 2.2 DTi of 2000. And the car don't start. The error code was p1630. But now when e remove the pump i see a strange thing. When remove the protection of wires, the two "black" wires are not black because the rubber protection was destroid. Can this burn some sensor?? Or just have error?? I need to repair the mosfet transistor or not?
  13. #1363
    Jul 2019
    Can anyone helps me?? Can be the problem of my car won't start because the wires being together?
  14. #1364
    Nov 2016
    Can someone please help me, I have swapped out two different transistors on two different boards, both come up with the same error. All the solder points look good, I've uploaded photos, I used 2905 transistors
  15. #1365
    May 2020
    Romania
    IRLR3110ZPBF 100V 63A 140W work Audi 2.5.
  16. The Following User Says Thank You to kovach For This Useful Post:
    Yhoni (18th January, 2025)
