Page 82 of 98 FirstFirst ... 3272777879808182838485868792 ... LastLast
Results 1,216 to 1,230 of 1463
  1. #1216
    Vegaz
    Hi guys,
    What's the best transistor for OPEL X17DTL, 0 281 001 371, 0470 004 003 ?
    I have this 2905, 3803, 44n25, 3705, 3205.
  2. #1217
    Jan 2018
    hello, i have a bmw 320d with vp44 pump. I replaced the transistor with IRLR 2905 PBF and now i get inpa error "Pump controll unit-EEPROM or ADC defect" . attached you have a picture of the way i soldered IRLR2905PBF. i used this method : .
    What could be the problem? is this the correct transistor or shoul i use AUIRLR2905Z or IRLR3705Z ?
  3. #1218
    Nov 2017
    We send the VP44 electronic and the people repair like this (picture)
  4. #1219
    Feb 2016
    Hello tanks
  5. #1220
    RO-SJ
    Quote Originally Posted by anjo008 View Post
    #anjo008 How do you remove that caps from ceramic board? They aren`t just solder, they are fixed with epoxy aswell.
    Thank`s
  6. #1221
    Nov 2017
    Quote Originally Posted by dorcky View Post
    Thank`s
    Good question. This work was from my dealer... I try with other that I have broken and I say something....
    Sorry.
    We continue learning.....
  7. #1222
    Nov 2017
    Anyone know if I need replace the transistor?
    Or only soldering...
  8. #1223
    Feb 2011
    Replace transistor!
  9. The Following User Says Thank You to denzl For This Useful Post:
    anjo008 (24th February, 2018)
  10. #1224
    Nov 2017
    IRLR 2905, IRLR 3110 or IRFZ44?
  11. #1225
    Feb 2011
    Only IRLR2905
  12. The Following 2 Users Say Thank You to denzl For This Useful Post:
    anjo008 (25th February, 2018), BusCan (11th July, 2018)
  13. #1226
    Nov 2017
    Soldering with Sn60Pb40 is it good? Or I need special product?
  14. #1227
    Feb 2011
    Yes good...I can help you but write to me for private
  15. The Following User Says Thank You to denzl For This Useful Post:
    anjo008 (1st March, 2018)
  16. #1228
    RO-SJ
    Default Anyone knows?
    Anyone knows where this terminal goes ? Thx!
  17. #1229
    May 2018
    I damaged the pad where the drain connects to the circuit board, anyone know an alternative conection point?
    Does anyone know what the drain terminal connects to on the circuit board pictured? A flyback diode perhaps?
    What about the other drain connection pin on the bottom right corner? Is this one of the solenoid leads? Which is the other solenoid lead?
    Is there a schematic or circuit diagram available so I can better understand this circuit?
  18. #1230
    May 2018
    I cannot see any reason for the mosfet drain to be connected to the circuit board, other than for transient protection of the mosfet. Because I can't solder to the PCB drain pad, I propose to fit my own protection zener diodes as pictured. Any thoughts on this?
    Is there any information showing points where the solenoid wires connect to the PSG? I'd rather not interfere with the insulation on the solenoid wires to find out.
