Page 92 of 98 FirstFirst ... 42828788899091929394959697 ... LastLast
Results 1,366 to 1,380 of 1463
  1. #1366
    May 2020
    Romania
    IRLR 2905ZPBF 55V 60A 110W work Opel .
  2. The Following 4 Users Say Thank You to kovach For This Useful Post:
    BusCan (13th July, 2021), sash2006 (13th May, 2021), stang (14th January, 2023), Yhoni (18th January, 2025)
  3. #1367
    May 2020
    Romania
    IRLR 3705Z 55V 89A work Ford.
  4. The Following User Says Thank You to kovach For This Useful Post:
  5. #1368
    May 2020
    Romania
    IRL 3803 work BMW.
  6. #1369
    Nov 2016
    Quote Originally Posted by pugbug View Post
    Can someone please help me, I have swapped out two different transistors on two different boards, both come up with the same error. All the solder points look good, I've uploaded photos, I used 2905 transistors
    Anyone got any ideas for this please? I'm pulling my hair out. Is there any way to test the transistor? Thanks,
  7. #1370
    Oct 2017
    hi
    i need the password please
  8. #1371
    May 2020
    Romania
    This P1651 cannot be repaired.
  9. #1372
    May 2020
    Romania
    https://www.youtube.com/watch?v=ydwzUSeH-4A
  10. #1373
    Nov 2016
    Quote Originally Posted by kovach View Post
    Thanks, I've seen that already. I soldered up exactly using that schema. Is there any way of powering up the transistor to an output such as a bulb to see if it works? Soldering is fine so I don't understand why it does not work I have two codes p1651 p1631 no CAN communication
  11. #1374
    Mar 2013
    I know that someone on this thread will disagree with me ,but I ve noticed a catastrophic drop in succes rate on Fords when changing from irlr3110zpbf to irlr3110ztrpbf, because TME has no more in their offer
    I have no other explanation ,even transistors seems to be equivalents , but facts are too obvious
    I think that I ll try 2905 ,even is not most suitable for Ford ,but last one survived one year on a Ford ,but again ,it was a zpbf also..
  12. #1375
    Nov 2017
    Need the transistor 2905 or whatever special sealant or glue down????
    I tried soldering transistor un vp ford and it was not succesfull.
  13. #1376
    Aug 2016
    Hello
    I have a problem with soldering the wire to the plate or can someone tell me what tin to use
  14. #1377
    hi guys.
    i am working on opel zafira, 2003 year, 2.0
    faults:
    -sensor of rotation
    -no fuel
    -when you press gas pedal, nothing happens.
    any ideas?
  15. #1378
    Aug 2020
    Quote Originally Posted by lukasz12345 View Post
    Hello
    You need to use flux also not just solder.
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  16. #1379
    Hi guys.
    Have problem on opel Zafira, psg16.
    Problem is dtc: p0340
    when it is hot, doesnt want to start.
    Camshaft sensor on pump was replaced.
    Any ideas...?
  17. #1380
    Newbie badici's Avatar
    Dec 2019
    Romania
    Hello. I have an Audi A6 C5 2.5V6. Can you tell me if codes are generated in the injection pump engine group? The machine stopped idling.
    17978
    01318
    00519
    00546
    And in the group "tools" I still have 01312.
    If you can help me with advice, please. Thanks!
