Results 1 to 15 of 15
    Busswil Switzerland
    Default Reno kangoo dcm1.2 r0410b041c 81399a
    Hallo to all
    i have problem renew engine ecu on renault kangoo 2009 1.5 dci i need help and will to pay for working solution.
    i try to transfer 95160 from original ecu program injector and car not start fault DF024. i try to renew with immo tool don't.
    Thanks in advance
    Kozloduy BG
    Smile kangoo
    Test....and report.
  3. The Following User Says Thank You to esxo For This Useful Post:
    Babanovski (5th April, 2019)
    Busswil Switzerland
    I allready try this sollution and i have 2 fault df024 and engine ecu. after coding injector is just df024 and car not start.
    this is solution don't work or i'm doing someting wrong
    Kozloduy BG
    Which version is your can clip?
    Busswil Switzerland
    i have v92. what is procedure after writing virgin file. injector coding and auto start or i need to program someting with clip.
    Kozloduy BG
    What is the problem with the old ecu?
    DF024 0231 Low pressure actuator control circuit
    Busswil Switzerland
    after welding on car ecu is brned and no communication with ecu i try to read on boot st but not possible.
    and i search df024 low pressure actuator control circuit is releted to immo. when i check mes. value immobilisator is activ.
    auto not crunk.
    Kozloduy BG
    Default kangoo
    This option tries it?
  10. The Following User Says Thank You to esxo For This Useful Post:
  11. #9
    Busswil Switzerland
    i try i can't code injector and cant dellete faults.
    df648 computer
    df024
    immobiliasator activ
    code programed no
    and car not start
  12. #10
    Kozloduy BG
    Тhe dump from the first post is the original of the car?
  13. #11
    Busswil Switzerland
    No is not original from car computer. this file is from used ecu.
  14. #12
    Kozloduy BG
    UCH dump?
  15. #13
    Kozloduy BG
    UCH dump?
  16. #14
    Busswil Switzerland
    here is uch dump
  17. #15
    Busswil Switzerland
    Is it possible immo off this car witout emulator?
