I have problems with Immo in seat leon 2 year 2006 , I remove Immo with Vvdi2 via obd , but the message SAFE is in cluster... the car not recognize any keys, not can learn keys, how I can remove this SAFE of cluster ???
Hi do you have the pin code ? Programme the keys by any obd like VCDS or VAS5054a go to channel address 25 immobilizer than security access and put the pin code than go adaptation channel 21 put how many keys you wont until 8 if you have and press okay than change between keys to teach the system , if you need any help send me teamviewer I can help you remotely, Regards Dani.
If you made immo off in ECU, it isn't possible to learn keys.
SAFE will just go away when you learn a valid key to it.
Yes have you try as I say ? It must work 100%100or send me teamviewer I help you
now immo is ON , the car not recognize de keys , i not can learn keys ....... i think the problem is the cluster .... i change also coil ingnition without lucky ....
Give me teamviewer on your diagnostic that is connected to car
We must know also is the right chip you are using?
You can check with VCDS if the key is detected or not.
It will also tell you if the key coding is correct for this car or not.
Check measurement blocks in Address 25.
Block 001 and 002
If you have 1 new chip please put it inside the key and give me teamviewer
ID 48 can
friend have 2 keys with perfect chip , the problem is that the coil not recognize the keys ( the coil is new ) , i not can learn new keys ..... maybe i think disable this message modified ecu eeprom ??
You cannot deactivate this message from ECU. This message is created by dash because of undetected key.
Swap dashboard or try to repair it.
m35i (11th April, 2019)
Yes exe123 is right try put another dash to see it is seeing the keys or not than wiring from key ring to dash must be checked , I wish we are helping you my friend, Regards Dani.
