Hi Friends.Looking for some tips how to repair ford mondeo mk4 instrument cluster.Lcd works only in half part,also lighting goes crazy.All points are reflowed.Changed lcd display from another dash no luck.
Please dear members push the button if my work was helpfull!
And reputation button(star)
drewdom (13th April, 2019)
check flex of screen display
drewdom (14th April, 2019)
What is flex? I replaced all screen from other dash and the same.
Maybe you need to check some capacitors or resistors. You can use a multimeter for that.
drewdom (17th April, 2019)
This is what jomberykaso mean check this 80% the reason of ur problem images.jpg
drewdom (15th April, 2019), jomberykaso (15th April, 2019), Stelaras26 (15th April, 2019)
No it is not because I heave 2 clusters and allready swaped this screens between them and only one give result like this.Here is other one with screen taken from broken one but in this one gauges don't work.
Probably just mcu problem.
It's typical problem for ford dash.
drewdom (16th April, 2019)
The problem solved by change cluster with not working gauges.It was enough to resolder the mcu and wite flash and eeprom from original one.
