Results 1 to 15 of 22
    Feb 2014
    london uk
    Default Cas 3+ help with damaged cas
    Hi guys can anyone help me to repair a damaged cas from a 2011 mini cooper. cas was damaged during bad key programming and im not sure how to check if the flash or eeprom is damaged as i was not there when the technician attempted the cas update!! have posted eeprom and flash below and cas part numbers
    anyhelp would be appreciated.
    also is there any software out there that will automatically check the files and repair cas for you without spending too much on autohex?
    Mini cooper 2011
    cas 3+
    61.35-9221719-01
    C4 20.8 09 06A0
    5WK4 951CBR
    mcu mc9s12xdp512cal
    mask OL15Y
    thanks in advance.
    Aug 2015
    BEHIND YOU
    buy another cas3 same part number
    and write original eeprom to second cas....
    for me writing good flash did not worked on the mini cooper... but you can try....
    but writing orignal eeprom to second hand cas will work
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  3. The Following User Says Thank You to eliaselias For This Useful Post:
    Mrcarkey (18th April, 2019)
    Nov 2016
    Hello friend
    Just rewrite the flash
    Done and enjoy
    Enviado desde mi iPhone utilizando Tapatalk
    Usa
    CAS is in boot mode.
    Play this dump.
  6. The Following User Says Thank You to hojo25 For This Useful Post:
    Feb 2014
    london uk
    Have you checked my files and they are ok?
  8. #6
    droidwayne65's Avatar
    Aug 2015
    North America
    Quote Originally Posted by Mrcarkey View Post
    Eeprom shows a 9287535 part number, so here's the eeprom in user mode and a matching Flash.
    <---- Coin of the Realm.
  9. The Following 9 Users Say Thank You to droidwayne65 For This Useful Post:
    jsnlam (27th July, 2024), meethemeat (7th January, 2020), milehighlockdoc (3rd May, 2019), Mrcarkey (19th April, 2019), newone (2nd May, 2019), nikola111 (17th April, 2025), weld88 (26th November, 2019)
  10. #7
    Feb 2014
    london uk
    Thank you i will try tommorow and report back ��
  11. #8
    Feb 2014
    london uk
    so need to just write your flash and eeprom back to cas and all should be ok?
    Thankyou
  12. #9
    Aug 2015
    North America
    Thankyou
    Yup. Write both, install, say a prayer then push the button.
  13. The Following 4 Users Say Thank You to droidwayne65 For This Useful Post:
    cniksor (17th May, 2019), milehighlockdoc (3rd May, 2019), Mrcarkey (19th April, 2019), newone (2nd May, 2019)
  14. #10
    Feb 2014
    london uk
    Wrote both files back added second key with tango and car started up with no problems. Thank you so much for the help saved me time and money buying new cas from the main stealers
  15. The Following User Says Thank You to Mrcarkey For This Useful Post:
    p1et (2nd May, 2019)
  16. #11
    Did you not forget sent some of your savings to droidwayne65 for his valuable time and incredible effort to help you?
  17. #12
    Aug 2015
    North America
    Quote Originally Posted by qwojtus View Post
    LOL, hear, hear ! Nah, clicking the buttons is enough.
  18. The Following 5 Users Say Thank You to droidwayne65 For This Useful Post:
    CC Lock (3rd May, 2019), cjawahir (21st October, 2019), milehighlockdoc (3rd May, 2019), Mrcarkey (4th May, 2019), schmidti33 (22nd May, 2019)
  19. #13
    Jun 2018
    Germany
    Hello guys,
    A friend of mine asked me for help with his defective CAS, which probably has a similar problem (corrupt dump). So I am searching for some basic info as I am not that familiar with BMW CAS. Which tool do you use to write?
    Thanks in advance
  20. #14
    Becoacamba's Avatar
    AnyWhere
    Quote Originally Posted by CTraute View Post
    Hello guys,
    Thanks in advance
    a good one cheap it's xprog
  21. #15
    Europe
    Be carefull with clone Xprogs, especially don't use old versions like 5.51 and 5.55 on CAS.
