Results 1 to 12 of 12
Thread: BMW Key Cloning
    Oct 2018
    Northern Ireland
    Default BMW Key Cloning
    Mixed views on this so looking someone who’s done this
    E-series diamond key if cloned original will drop out but will clone still continue to work?
    Was wanting to do Keydiy remote ID46 clone key and add remote manually
    Thanks in advance 👍🏻👍🏻👍🏻
    HeXeN's Avatar
    Mar 2015
    what model? id46 cas2 for example e60 you can clone. old key will work ok.
    but ews type pcf7930/35 remember once I had e46 towed to me because one locksmith tried to clone it and after that original key stopped to start a car.
  3. The Following User Says Thank You to HeXeN For This Useful Post:
    Jimmy07 (30th April, 2019)
    Oct 2018
    Northern Ireland
    Thanks Hexen
    Just a general question
    Are all ID46 BMW ok to clone or what models are covered ?
    Can CAS3 be cloned ?
    ghostrider72's Avatar
    Jul 2012
    UK
    No you cant clone cas3
  6. The Following User Says Thank You to ghostrider72 For This Useful Post:
    Oct 2018
    Northern Ireland
    Thanks mate always looking quick solution but it’s not to be 😬
  8. #6
    HeXeN's Avatar
    Mar 2015
    Also CAS1 you can clone, but CAS3 never tried beacause I always make remote key.
  9. The Following User Says Thank You to HeXeN For This Useful Post:
    Jimmy07 (2nd May, 2019)
  10. #7
    p1et's Avatar
    Oct 2013
    It doesn't matter CAS1 or CAS3 - all can be cloned, it's ID46 chip. Only CAS3+ you might fail to clone. But as for today there are many devices which can program fully working BMW remote/smart keys. Cloning was good option maybe 6 years ago when there were only very expensive tools for make OBD programming and not many wanted to eeprom them.
  11. The Following User Says Thank You to p1et For This Useful Post:
  12. #8
    Dec 2010
    Nottingham
    yup cas3 can be cloned , in fact both keyline and silca sell the pod keys to clone for use on their machines , but no remote functions just for starting car as emergency keys
  13. #9
    Oct 2018
    Northern Ireland
    Some bladed e series are manual remote programming so might be an option
    Thanks everyone 👍🏻
  14. #10
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    E60/E61/E63/E64 Diamond key is not a manual remote programming...
  15. The Following User Says Thank You to simaservis1108 For This Useful Post:
  16. #11
    Oct 2018
    Northern Ireland
    Thanks for replys 👍🏻👍🏻
  17. #12
    Mar 2019
    If it's an ID46 then you can clone it and the original key will be fine. But I've yet to try and clone the push in the dash keys yet, purely for the fact noone has ever asked for one without remote on.
    If it's an ID73 Key (BMW x5 old, E46 etc) then i've heard you run the risk of the old key not working when you clone because its a rolling code. Easiest way is to program a PCF7935 into the ews unit and code the remote manually.
