Results 1 to 15 of 29
    Jan 2018
    Default Vivaro 2.5 Dash + milage & Oil light reset problem
    I replaced the damaged instrtument-cluster,
    For used mileage 212k // Im change to 168k so that it matched to the counter.
    After 2k miles the service light came on, I could not delete the inspection. I added miles to 185k and managed to put out the inspections.
    Unfortunately, after another 200 miles, it lit up again.
    Now I tried the same and after adding 3-5k I reached 235,000 and the inspection still lights up
    All option checed , battery disconection, waiting 5-10min betwen try etc...
    error of improper oil quality.
    And not the proper instrument cluster configuration.
    Service light still on
    What can I do with it now?
    EEP 24c66
    Vivaro 2007 - 2.5cdti
    Dash X83 ABVR GB GM Bus v4.7
    P8200279057 - D
    Last remembered mileage 176.000 +/- 5k
    How can I solve this problem ??
    I will be grateful for any help.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Reset the service indicator light on Vauxhall Vivaro?
    How do you reset maintenance light, reset service light indicator Vauxhall Vivaro. For reset maintenance light and that can be made manually by use button on car dashboard.
    Reset service light indicator, engine oil life Vauxhall Vivaro, oil reset instructions:
    1 ignition off
    2 put accelerator to the floor,
    3 ignition on – still holding throttle pedal then pump brake 3 times.
    4 release throttle pedal
    5 switch ignition off
    Jan 2018
    Quote Originally Posted by teerak2uk View Post
    1 ignition off
    I have tried all combinations with the pedals.
    The first time I succeeded after adding miles to 185k,
    unfortunately now I can not do anything.
    Miles are add up to 235.00 and nothing changed.
    service light on and bad oil quality etc...
    Clear Errors and oil quality come on again after 2sek.
    1307 miles left to service and xmass tree on dash
    Lost power etc...
    renolink - to deal with this problem, or/ no chance ??
    Jan 2018
    The eBay instrument cluster (attached file 235k miles)
    and the service indicator light immediately turned on.
    Currently 171k +, the Counter from January 165k
    Jul 2016
    Ukraine
    To reset the service with pedals it is necessary that the difference in mileage in dash and ECU is not more than 10 miles. There are several ways to solve this problem. Using CanClip, level the km by resetting the ECU and re-register the injectors. But CanClip is easier to transcode dash from type 2 to type 1 in coding UCH. Or manually change the mileage in the ECU. If the renolink allows you to do this encoding can be done with this device. I use сanclip
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by urametz View Post
    To reset the service with pedals it is necessary that the difference in mileage in dash and ECU is not more than 10 miles. There are several ways to solve this problem. Using CanClip, level the km by resetting the ECU and re-register the injectors. But CanClip is easier to transcode dash from type 2 to type 1. Or manually change the mileage in the ECU. If the renolink allows you to do this encoding can be done with this device. I use сanclip
    I've done plenty with pedals and km has been 10k+ difference at least
    Jul 2016
    Ukraine
    Believe me, this is not always possible, especially since in this case the dash has changed and there is an error in the encoding. Sometimes, to reset the service with pedals, you can increase the mileage in dash, for example, by 200k, reset it with the pedals, and return mileage again. But in this case it is easier to change the type of dash in coding uch.
  8. The Following User Says Thank You to urametz For This Useful Post:
    teerak2uk (1st May, 2019)
    Jan 2018
    Unfortunately, this is the problem.
    I tried to increase mileage, and reset by combination of pedals.
    I increased 5,000 miles from 170k to 235k (oryginal milage counter 235.350miles)
    In all attempts, unfortunately, the light control does not go out.
    So this is clearly a problem with the configuration of the instrument cluster.
    " But in this case it is easier to change the type of dash in coding uch."
    Can you explain more accurately ??
    Thx
  10. #9
    Jan 2018
    How to check mileage in ECU
    Unfortunately, my Clip does not work (problem with probe etc..)
    I have OpCom, Delphi, I'm waiting for Renolink.
    In Delphi millage is 2.986.675 ????
  11. #10
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by robarco View Post
    I use smok obd but maybe open and read eeprom from it
  12. #11
    Jul 2016
    Ukraine
    To do this, it is not necessary to have a canclip. There is a free DDT2000 program that uses the usual ELM327 and all CanClip scripts with DMA as well as simple coding. By the way, renolink uses the same principle and the same scripts. You will find everything on the network.
  13. The Following User Says Thank You to urametz For This Useful Post:
    robarco (3rd May, 2019)
  14. #12
    Feb 2017
    Baltic
    you need to reset service before the service light comes on, some of those cars have that bug.
    OR fix km in engine ecu so it matches cluster.
  15. #13
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mikkhh View Post
    Or at least reset service before changing km .
  16. The Following User Says Thank You to teerak2uk For This Useful Post:
  17. #14
    Bllinda's Avatar
    Baltic
    Post Can Introduce Yourself
    Why should I help you? You couldn't help anyone over the years
    EEP 24c66
    P8200279057 - D
    View the eeprom where data is changing
    Thx
    today
    A topic that interests me
  18. #15
    Jul 2016
    Ukraine
    Quote Originally Posted by Bllinda View Post
    Where service data changes have long been known this is the area 0000134 - 0000153. You can put 0 or 20,000 to the service. But here I understand the problem in another. The man is a little off topic. He already had a problem with this dash: https://www.digital-kaos.co.uk/forum...66-with-board- computer .
    Over the past year, if desired, it was possible to parse the entire dump dash byte-bye. And here we are spreading on the tree is useless.
