Results 1 to 15 of 18
    Oct 2015
    LV
    Default Citroen c4 picasso bsi problem
    Hi all,
    Can anybody explain me trouble with car bsi.
    Car is Citroen c4 picasso exclusuve, 2.0 hdi, 2008 year with bsi JC 966405878001 BSI04EV K01-00, signature dc.04
    Problem is when car no ignition, after turning key, dash and ecu not wake up.
    Tried reflash bsi with the same signature, but simphtoms stay the same. Tried again, but now take other signature flash. After bsi flashing on the table open fvdi bsi identification screen and ...signature and software nr. not changing - stay old, just changed software index. Tried again with different signature flash, check again, but in the identification screen signature and software nr stay the same. Why after flashing not changing this two things? Something is bad with bsi microchip?
    Here is possible something to do or need find new bsi? Try to write, set vin and pin and after that read flash. After read tried read pin with other software, but cant.
    For this car is changed ecu und bsm modules too. For bsi pin code is the same as ecu.
    This bsi which now stay on car is already changed, because with old was the simalar problems...
    I attached file (example) where can see what changing after flash different files and what not.
    Can somebody also make bsi eeprom dump virgin?
    Sent from my Redmi 4 using Tapatalk
    Jan 2016
    I think your problem is it something else.
    VF7UARHJ45383214
    PIN FCVB
    Le-Mans's Avatar
    Jun 2017
    i confirm with marianro2007
    Oct 2015
    LV
    Vin and pin i know from this dump, need make this dump virgin....
    So, but where can be problem than after file flashing signature and software not changing stay old, but changing just index.
    Le-Mans's Avatar
    Jun 2017
    Here virgin dump but i believe you need a good flash for bsi
    PSA Group File Service Solutions, Support & More
    Half-knowledge is worse than ignorance
  6. The Following User Says Thank You to Le-Mans For This Useful Post:
    Jancis (9th May, 2019)
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  8. The Following User Says Thank You to kiszka For This Useful Post:
    rafal (9th May, 2019)
  9. #7
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by Jancis View Post
    Try with another one eeprom.
    Load flash for check!
  10. The Following User Says Thank You to brend For This Useful Post:
  11. #8
    Oct 2015
    LV
    I have two bsi with identic nr ...tried put in car, no ignition, no dash and ecu wake up, tried using diagbox make coding..the same.
    I attached both flash files from bsi1 and bsi2
    Possible than flash not good or something else, but what?
    I get some flash files from user Doctor, too, thanks him, but till this moment nothing changed after reflashing bsi. Still no ignition, no wake up dash and ecu.
    I havnt idea what do do.
    I also change to another BCM and ecu, but still nothing happen
  12. #9
    Oct 2015
    LV
    thanks LeMansSeries for dump..please pass from archive.
  13. #10
    Bllinda's Avatar
    Baltic
    Lexia has ....
    Which car do you start?
    VF3WCKFUC.... Peugeot 207
    VF7UARHJH.... C4 Picasso
    today
    A topic that interests me
  14. #11
    Oct 2015
    LV
    Quote Originally Posted by Bllinda View Post
    Lexia has ....
    VF7UARHJH.... C4 Picasso -> this
  15. #12
    Bllinda's Avatar
    Baltic
    bsi sticker photo
    P.S. helped you press the button
    today
  16. #13
    Oct 2015
    LV
    Here will be...
  17. #14
    Oct 2015
    LV
    So, today tried flash back virgin bsi eeprom dump, than connect to car and with diagbox make coding... still nothing, no ignition, dash and ecu not wake up...
    where can be problem??
  18. #15
    Le-Mans's Avatar
    Jun 2017
    As i said in 5 post need to try good flash for bsi
