Results 1 to 15 of 16
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    Default Smart for two 450 Sam module cloning
    Hello guys I have a smart for two that it has an issue with the high bean,and I am replacing Sam module because it seems to be the problem.
    Now i do need some help,i have no xprog or something similar to read the chip that stores everything,can I use car prog ? If not can I swap chips ? Or anyone has had a similar issue
    Στάλθηκε από το SM-G928F μου χρησιμοποιώντας Tapatalk
    TO TUNE OR NOT TO TUNE
    epicsabi's Avatar
    Budapest
    Maybe works with carprog mcu programmer. Read the eeprom from motorola and write to another sam.
    The mask is same?
    This sam I read/write with UPA.
    Az én iPhone készülékemről küldve a Tapatalk segítségével
    If I help you don't forget press the THANKS and REPUTATION buttons
  3. The Following User Says Thank You to epicsabi For This Useful Post:
    311786 (17th May, 2019)
    Feb 2017
    Thanks any info how to connect the car prog adaptor
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    when you have star, developer, C4 or C3 and or Vediamo you should do it without soldering...
    only VIN and Kilometers will be stored from donor car...
    but you´ll have no (big) issues...
  6. The Following 2 Users Say Thank You to figani For This Useful Post:
    alexandrosts (10th May, 2019), zecas (16th May, 2019)
    Feb 2017
    If I swap mcu will it work?
  8. #6
    Feb 2017
    I did synchronise the info with the MERCEDES diagnostic but I I don't get the miles
  9. #7
    Feb 2017
    The immobilizer is correct I just need to synchronise the miles and the vin so it will show miles on my cluster
  10. #8
    figani's Avatar
    Feb 2018
    yes, when you swap mcu it will work...
    first you have to desolder the upper pcb, to get to mcu...
    with star and so on...
    miles in dash will stay yours...
    the miles from donor car will only stay in sam, you will not see them in dash display...
    only when you turn ignition off, instead of miles in dash it will show - - - - - -...
    when you give ignition again, your miles will stay again...
  11. The Following 2 Users Say Thank You to figani For This Useful Post:
  12. #9
    Feb 2017
    Ok so if I swap the mcu from original Sam module with issue in the high beam, to the used donor Sam module will everything will it be ok ? Because all I need to do in donor Sam is the vin and miles the immo is already synchronized with star. It just the problem that I am having ---------- on my cluster
    Is never done this so I want to make sure before I desolder anything.
    And I do have carprog if anyone has a picture showing how to read mcu please help
    Sent from my SM-N920T using Tapatalk
  13. #10
    figani's Avatar
    Feb 2018
    To change VIN in Eeprom you need checksum correct after...
    Or reset miles in donor SAM...
    And write donor sam VIN to Eeprom in dash...
    And all is solved...
    By the way...when I help you press Thanks and Reputation...
  14. The Following 2 Users Say Thank You to figani For This Useful Post:
  15. #11
    Feb 2017
    Sure no problem. Ok hold on now I am confused. Is it the miles immo and vin on the mcu or it has a separate eprom for miles and vin ?
  16. #12
    figani's Avatar
    Feb 2018
    Quote Originally Posted by alexandrosts View Post
    Both in mcu/Eeprom...
  17. The Following User Says Thank You to figani For This Useful Post:
  18. #13
    Feb 2017
    Ok perfect so I will swap my original mc to donor Sam module and I should be good to go them
  19. #14
    Feb 2017
    So feedback on the job,for some reason did not work,alarm stock on horn stuck on no programming on the key the swap did not want well I am not sure what I did wrong ,soldering and desoldering was properly done,not sure what was the issue
  20. #15
    figani's Avatar
    Feb 2018
    you have comunication by obd with SAM unit...?
