Hi everyone, can someone tell me the procedure to program a key in a 2012 VW Passat?
I have FVDI-2014 and have downloaded a file from the Immo (Cluster by CAN button), can someone give me the pin?
wbr
wbr
Immo in Passat os not in cluster fella. Its in Convenience box behind the glove box.
The immobox, behind the glovebox. It has a 95320 eeprom.
Usa type passats, some have immo in cluster.
You will need the 7 cs bytes and pin.
Best to read these from the immobox.
You pin is also in the ecu,
And 6 bytes are in the ecu aswell, with these 6 bytes, you can look for the 7th byte.
Or look for someone that can clone your id48.
Or do you have keyless go equipted car? id46.
Allright, so it is not a Usa type car.
Still cant tell if it keyless, id46 or id48. Nevermind that.
I dont know what module you read, your dump is no good.
And post dump of the 95320. Module like this 3C0959433R
Pin code is not ennough, you also need the cs.
I only have access via OBD2, I've got an FVDI and all videos show it does this car by this dump.
On the videos it shows it picking up the 7 digit code but this hasn't, the new key isn't mine,
it was supplied by my key supplier, instructions also mention this dump.
https://www.youtube.com/watch?v=JwkK59JXZsM
Mine is a different key but instructions said it was the same.
shooting (12th May, 2019)
Hello Ian,as others said above for this car you need to read comfort module behind glove box for akl situation,if it is for spare key you can read dta forom car and find the seventh byte from the excisting key,also id48 no keyless id46 keyless
the other easy way is to clone chip and then program remote from obd
