Hi i have a fiat 500 continental A2C30468000/51918659 that has no communication anyone know repair for this unit
hello
i have this problem
same fault here .
did anyone find solution ?
please add rep & thanks if my post was helpful
i have the same failure, no communication.
have anybody some solution ?
i replaced unit . no fix i believe
Pali33 (8th April, 2020)
replace unit and replace/clone the eeprom 95320 ?
not confirmed, but this may work.
https://www.ebay.co.uk/itm/IC-apacea...gAAOSw1KRcC6EE
“There's nothing more dangerous than someone who wants to make the world a better place.” ― Banksy
Hello to all. After slick_dick post I found this https://xn--80aackhmik6acgcci5acrf9g.xn--p1ai/?p=2587 it is about that IC being a voltage regulator, and the replacement of this IC in mazda airbag ecu is needed when no diag, or random problems with airbag light.
fuzz1 (4th January, 2024), Pali33 (8th April, 2020), slick_dick (8th April, 2020), SUPUN1 (30th June, 2023)
yes, i thing you are right. I have on the PCB no 5V (or 3.3V) for MCU.
MCU work not.
The 5V goes from tis ATIC voltage regulator.
So i thing, this IC is faulty. But i can not test it now, mabe next time.
Thanks for info!
BusCan (21st February, 2022), slick_dick (8th April, 2020)
Where in Europe can I buy a working power driver apaceatic65v71 A2C00024016 for Fiat?
did anyone come accross on finding what the common fault is causing this issue after
