Results 1 to 7 of 7
    yarokas's Avatar
    May 2019
    Portugal
    Question Infineon C167 read\write IROM
    Hi guys
    I'm trying to read C167 internal ROM. Already tryied with Minimon and FLASHit and can't connect. Processor enters in BSL mode and even once returned the ID number "C5" but nothing more. Im connecting on Rx and Tx pins directly in the processor and pull a 8k resistor from POL.4 to ground as the datasheet tels.
    The ECU is EDC15P+.
    May be someone had allready did that and can share the connections and hardware\software used to do so?
    Full part number ? Some of the derivatives is ROMless.
    And why you need ROM ?
  3. The Following User Says Thank You to Zmann For This Useful Post:
    yarokas (24th May, 2019)
    yarokas's Avatar
    May 2019
    Portugal
    ECU: 0 281 010 305
    CPU: b58937 1037359446
    I need to disable the checksum.
    My guess is you can't find the original no. but only Bosch B58937, anyway it much possible to be C167CR-LM
    which is ROMless. If in doubt and you having Piasini, may try its available "C167 Internal" menu but I never.
    edit: I don't know Minimon but you may try K-line with k-line tool.
  6. The Following User Says Thank You to Zmann For This Useful Post:
    yarokas's Avatar
    May 2019
    Portugal
    So.... i did it. And it have 32kb of IROM
  8. The Following 4 Users Say Thank You to yarokas For This Useful Post:
    Faraday (7th April, 2023), Niaz (14th May, 2024), Pyromaniak (16th May, 2020), tatyanka (29th October, 2019)
  9. #6
    Sep 2019
    Did you use Kline to read it or did you use the tx and rx pins?
  10. #7
    Nov 2022
    Quote Originally Posted by yarokas View Post
    how?? you do??what is connection
