    May 2019
    Default I'll pay for Immobilizer off on a 2007 Subaru Forester
    Hello. I'd like to replace the ecu in my brother's 2007 forester with a used unit. It is difficult to find a matched ecu/immobilizer/cluster/key so it would help me to disable the immobilizer code.
    Attached is pictures of his ecu and the actual binary file. Thank you for your help
    achaccha's Avatar
    Nov 2010
    It is not possible to work on the ecu and do magic to start the engine of your vehicle. you need to synchronize ecu with immo and dashboard. you should attach these data plus the reading of the key.
    regards
  3. The Following User Says Thank You to achaccha For This Useful Post:
    caliskan71 (31st May, 2019)
    brend's Avatar
    Oct 2015
    Same where
    Without sunhro sulution from me in this car only full clon flash and eeprom.Just eeprom not enought flash have same counter from eeprom.
    For sunhro load Body and Ecu eeprom.
    And which eeprom type from ecu and bcm?
  5. The Following User Says Thank You to brend For This Useful Post:
    rafal (31st May, 2019)
  6. #4
    Aug 2015
    BEHIND YOU
    Can not do immo off... Find similar ecu and just swap eeprom...
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
    brend's Avatar
    Oct 2015
    Same where
    Just swap eeprom not enough for this type ecu.
    Quote Originally Posted by eliaselias View Post
  8. #6
    Aug 2015
    BEHIND YOU
    for me its not a problem.... even if any part of car was missing before...
    but as he told that original ecu is still available... so swaping eeprom will do the job
