hi need me17.9.11 kia cerato ecu pin out or a/c pins
Description only in Russian.
thaeerkh (5th June, 2019)
i need a/c pins from this ecu
Hello to all. Pin 31 and 51 are for the engine cooling. According to the diagram above there are no AC pins on ecu.
thaeerkh (30th June, 2019)
there is a problem ecu ac compressor clutch witch pin for ac clutch
