Hi all
I have a 1.4i Corsa D with the Z14XEP engine. The car start very difficult when it stood for a while. It seems that when the car is cold, the fuel mixture is very lean. While trying to start it, i push the petrol peddle also and after the third to forth attempt it will start. While trying to get it to start one can hear that the engine is getting fuel but it seems to be to little. I have also observed that when I spray easy start into the intake a cold start is much easier.
Once the car is hot, it starts first time every time.
I have done the following:
- There are no error codes
- I replaced the 2 terminal temperature (multi function) sensor as this can cause too lean mixture during cold start
- Compression on all 4 cylinder is good and almost identical
- New spark plugs
- New air-cleaner
- Checked for vacuum loss on the intake.
- Checked the spray pattern of the injectors.
- Eventually when it starts (cold) the vacuum is 20.4 in/Hg (reported by the ecu)
What more can I check or try?
