Results 1 to 15 of 16
    Mar 2019
    Default BMW 5 E39 Siemens MS43 immo off
    Good evening. Possable to remove immo on bmw ms43
    ECU: SIEMENS DME MS43 5WK90012
    7 511 579
    b137c56g 430037
    Full flash of ms43 attached.
  2. The Following User Says Thank You to Gladi77 For This Useful Post:
    boost turbo (17th June, 2023)
  3. #2
    tunelab's Avatar
    Feb 2019
    Default ms43 immo off
    try this mate good luck
  4. The Following User Says Thank You to tunelab For This Useful Post:
    Gladi77 (13th June, 2019)
  5. #3
    Mar 2019
    Ok. Now I will try
  6. #4
    Mar 2019
    not working.
    May 2017
    report my friend.
    if ews unit broken please delete an bridge wire 1+2 in plug.
  8. The Following 2 Users Say Thank You to Lambda1 For This Useful Post:
    Gladi77 (13th June, 2019), mnem (2nd August, 2020)
  9. #6
    Mar 2019
    Quote Originally Posted by Lambda1 View Post
    report my friend.
    Only this solution works. Thank you.
  10. #7
    Feb 2014
    Portugal
    pass please
  11. #8
    May 2017
    put your own read.
  12. #9
    Oct 2017
    can i get a pass please
  13. #10
    May 2017
    No! Only Threaderstarter!
  14. #11
    Hello Lambda1,
    can you make me please Immo off for MS43 430037? All guides (like above) i found, does not work.
    Regards Max
  15. #12
    Hi, i could get the car to start with your solution for 430037 on RomRaider but now is the MIL on. DTC shows INPA Code 0 and 100 (DME Control Unit -Self-Test Failed). How could i get rid of this DTCs? I set 0x7099b from 02 to 00 but still INPA Error 0. Could someone help?
  16. #13
    Jan 2020
    Quote Originally Posted by MadMAXXX View Post
    Hello Lambda1,
    Regards Max
    Test, password in pm
  17. The Following User Says Thank You to PDXAutoworks For This Useful Post:
    MadMAXXX (23rd May, 2022)
  18. #14
    Quote Originally Posted by PDXAutoworks View Post
    thanks PDXAutoworks, I try this already. In my version was also 0x7099b at 00 with checksum corrected. The car starts but Error 100 and 0 with MIL on.
  19. #15
    Nov 2017
