Results 1 to 7 of 7
    rob h's Avatar
    May 2011
    Default Swift keyless 2006-2012
    37172-62JV0
    i need to add a smart key, to a Suzuki swift 2006.
    The insert blade, containes a id46 transponder.
    I could clone this transponder.
    The remote (keyless) part. Do i simply program this, as if it is a remote?
    Does that allow starting of the car?
    I have a used keyless remote, does it need unlocking?
    And will buy a new insert, with clonable transponder.
    Any help would be appreciated,
    Thanks guys,
    Jul 2016
    New Zealand
    Remote not locked, so you can use used remote. It programmed manualy. All smart function and remote buttons should work after programming. I did only cars from Japan, but I think Suzuki for other markets are same. Instruction for remote programming in PM. Good luck.
  3. The Following User Says Thank You to AEMan For This Useful Post:
    rob h (13th June, 2019)
    jodge's Avatar
    Mar 2017
    can i ask too?
    Hampshire
    As above, i did one a year ago program the blade inside the slot first, for remote timing is crucial: and sort of quick
    1 Sit in drivers seat, close all doors, all doors unlocked.
    2 Insert programmed ignition key (emergency blade) into ignition
    3 Press door locking switch (in the drivers door panel) to lock
    4 Press door locking switch (in the drivers door panel) to unlock
    5 Press door locking switch (in the drivers door panel) to lock
    6 Press door locking switch (in the drivers door panel) to unlock
    7 Press door locking switch (in the drivers door panel) to lock
    8 Press door locking switch (in the drivers door panel) to unlock
    9 Press door locking switch (in the drivers door panel) to lock
    10 Remove the key from ignition
    11 Insert key in ignition
    12 Remove the key from ignition
    13 Insert key in ignition
    14 Remove the key from ignition
    15 Insert key in ignition
    16 Remove the key from ignition
    17 Insert key in ignition
    18 Start engine and wait for 3 seconds
    19 Turn the ignition OFF
    20 Buzzer sounds and door locks are activated Press a button on the remote - a buzzer will sound and the doors will lock and unlock, repeat this for any additional remotes Doors will lock and unlock Turn ignition ON
  6. The Following 5 Users Say Thank You to nazz2 For This Useful Post:
    i_shot_the_sheriff (7th March, 2025), jodge (14th June, 2019), lion0304 (15th June, 2019), Meat-Head (15th June, 2019), u.s (7th May, 2021)
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by nazz2 View Post
    WHen you write insert the key blade in Ignition, what does that mean?
    Just insert or insert and turn ignition ON?
  8. #6
    Hampshire
    Yes, put the key in ,dont turn on.
  9. The Following User Says Thank You to nazz2 For This Useful Post:
  10. #7
    i_shot_the_sheriff's Avatar
    Nov 2008
    I know this is not the place to write but this is a question about this system ....
    Anyone knows how to program a second hand ignition switch on the Swifts ?
    I've installed a used ignition switch (because the original one does not open at all) and car starts ,, remote all programmed but keyless function does not work on the ignition! Keyless works on the driver's door but not on the ignition switch ,,,
    I've tried several used ignition switches but same result !
    Edit : Found it ! There is a small pcb inside the ignition switch housing (you have to open it ,.. very difficult) that contains a 24C01 eprom ! This has the keyless data ! I've moved this pcb from one switch to the other and keyless works now on the ignition switch !
  11. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
    Faraday (11th March, 2025)
