Results 1 to 7 of 7
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Citroen C2 front wipers + washer not working.............
    Hey mates
    I got a weird fault on a C2 and it's giving me a headache...! Just want some opinions....
    Front wipers and windscreen washer do not work at all... no DTC on the car ...
    So , i plugged my Lexia ,, did an activation on the wipers and it's successful, wipers work ! So , i' m rulling out wiper motor and BSM...
    Then checked the Live Data on the COM2000 and the stalk seems to work,,, but the Live Data on the BSI does not read the stalk movement at all...! So i thought it was a communication problem on the VAN between BSI and COM.... i've checked the wiring but it's faultless!
    So in generall i've tried these parts on the car:
    BSM changed...
    BSI plugged in 3 different BSIs (different numbers) but still same fault
    COM2000 plugged in one and same result (different part number too)
    I've also tried the BSI reset + COM2000 reset procedures with no avail
    Now i'm starting thinking that i need to test a COM with same part numbers.....
    Has anyone encountered this? Any suggestions would be much appreciated ,,,,
    Meat-Head's Avatar
    On topic
    https://www.digital-kaos.co.uk/forum...or-rear-wipers
    sadly the photos are now separate due to forum change
    https://www.digital-kaos.co.uk/forum...hp?albumid=224
    inshort unplug coms200 cycle ignition,?WAIT 2mins everytime
    Plug in cycle ign, wait 2 mins
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    i_shot_the_sheriff (14th June, 2019)
    Nov 2008
    Alright i will EARTH the shit out of it right now .......
    As for the COM reset i've tried it like 20 times and still nothing
    Meat-Head's Avatar
    Sadly can’t find the thread and external link dead
    what do you call com reset? Details?
    ON/off topic
    is is there any coins in radio shorting can?
    Nov 2008
    Do you think it needs a BSI software update ? I've checked every single configuration and it's correct inside the bsi ,,
    COM reset i call "unplugging the grey connector on the com ,,,, wait bsi to sleep , plug connector ,, turn ign on ,, move stalk to first scale ,,, then let bsi sleep again ,,,"
    Unplugging the radio ?? hmmmmm
    Nov 2008
    Update ,,,,
    I've plugged in a different BSI and now the washer works and wipers are working constantly !!! It seems it's indeed a bsi problem and car needs same parts numbers bsi! Or i will pay a visit to the dealer to update its software .......
  8. The Following User Says Thank You to i_shot_the_sheriff For This Useful Post:
    Meat-Head (14th June, 2019)
  9. #7
    Meat-Head's Avatar
    Is there any water in bsi?
    if not are you close to a river ?
