Results 1 to 13 of 13
    Junior Member PowerCheck's Avatar
    Jul 2019
    Argentina
    Default Dashboard failure when reading 93lc86, modification chevy Sonic / Aveo 2013
    Hello everyone, I have a problem with a chevrolet sonic / aveo 2013 dashboard. I read the 93lc86 memory to modify mileage, and when reading with the upa programmer, I read all of FF FF. I put the memory back in the dashboard and it does not show me mileage and turn on two lights that did not light before. I wanted to know if you can give me a help to return the dashboard correctly, and I learned that the mileage is modified in the BCM. I await an answer, and I apologize for the translation of the google translator.
    Jul 2017
    you read and did not program ?
    if you did not program it , it could be bad soldier eeprom.
    if i program the dump is corrupt you will have to find an equal one and copy the programming.
    km sonic stored in bcm.
  3. The Following User Says Thank You to manuel555 For This Useful Post:
    PowerCheck (10th July, 2019)
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Mileage is stored on bcm
    (Colegas, ese Chevrolet sonic lleva el kilometraje en la bcm, no en el tablero.)
  5. The Following User Says Thank You to jomberykaso For This Useful Post:
  6. #4
    Jul 2019
    Argentina
    Quote Originally Posted by manuel555 View Post
    manuel555: disassemble the memory and soldered the same on the PCB and check the correct state of the solders, and the fault persists. thank you very much await answer
    Enviado desde mi LG-M700 mediante Tapatalk
    Jul 2019
    Argentina
    Quote Originally Posted by PowerCheck View Post
    Hello to the people of DK. I wanted to know if someone has a backup dashboard (93LC86) of chevy Sonic 2014. I attach images of the dashboard. I appreciate your contributions ... !!!
  8. #6
    frankrayk's Avatar
    Aug 2015
    42 52 41 5A 49 4C
    Good luck.....
    If I was useful to you, thank you by pressing the thank you button .
  9. The Following User Says Thank You to frankrayk For This Useful Post:
    PowerCheck (12th July, 2019)
  10. #7
    Jul 2019
    Argentina
    Hello people: Someone who has a backup 93lc86 Sonic Latin America dashboard. Sonic or Aveo 2014. Thanks are welcome
  11. #8
    Hello, you can try this file, I do not know if it's compatible
  12. The Following User Says Thank You to mateos For This Useful Post:
    PowerCheck (13th July, 2019)
  13. #9
    Sep 2013
    First you need to put the same Vin Number from BCM or Chasis of car in this file.
    Good Luck!
  14. The Following 2 Users Say Thank You to jomberykaso For This Useful Post:
    PowerCheck (13th July, 2019), rtbdiagnostic (6th April, 2021)
  15. #10
    Sep 2013
    put vin number here
  16. The Following User Says Thank You to jomberykaso For This Useful Post:
  17. #11
    Jul 2019
    Argentina
    Quote Originally Posted by jomberykaso View Post
    put vin number here
    KL1JM5EE8EB502879
  18. #12
    Sep 2013
    Upload bcm file to sync with new file
  19. The Following User Says Thank You to jomberykaso For This Useful Post:
  20. #13
    Jul 2019
    Argentina
    Thank you very much Jombery for the contribution. Do not disassemble the BCM memory. The functions of the dashboard do not work well yet, so far with all the files q probe of the contributions do not manage to operate 100% the dashboard. Your last contribution of 16 bits improved by 80%, your contributions and experience are appreciated
