    Aug 2015
    Default abarth 595 ecu 0261s15048
    hi all i am mounting a abarth 595 1.4t 180hp engine into a fiat panda and stupidly i did not take full wiring/bcm/etc with me so im a bit stuck i need a immo off solution for the ecu 0261s15048 hopefully can be done through flash or emulator , please advise , thanks
    Aug 2015
    also does anyone have full pinout for this ecu? thnx
    Aug 2015
    hi all, quick update, i have spliced into the canbus behind the dashboard and sent a twisted pair of cables to the abarth ecu and now the key light goes out on ignition
    engine still not firing, i need to work through the other wires, such as throttle, clutch/brake switch, sensors etc, if anyone has done this conversion before plz message me
    Aug 2015
    Hi another update even though key light goes out the immobiliser is still active according to codes pulled from obd diagnostic tool i have opened ecu i will upload pictures later hopefully there is emulator or flash solution
    Aug 2015
    hi pictures as promised, plz any help with immo off solution ?
    Aug 2015
    bidding on a bosch 0261 201 756 ecu and corresponding engine wiring loom as this ecu is supported by julie emulator, obviously i would rather not have to buy this and change the loom, if someone has immo solution for my original ecu let me know, i can pay
