Page 1 of 3 123 LastLast
Results 1 to 15 of 43
    Jan 2016
    Default Renault Modus EPS DF002 fault repair
    Can anyone help with fixing DF002 in eeprom for renault modus 24c16 attached. Thanks
    Garage
    Try this file.
    Jan 2016
    nah man, still same problem
    Dec 2018
    что нужно virgin eeprom + программа написать eps
  5. The Following 9 Users Say Thank You to Catalizator For This Useful Post:
    byyoyo (27th January, 2020), kuzmanov (16th July, 2019), lobsterosxxx (16th July, 2019), martinracing (18th July, 2019), RedNix (7th August, 2019), snstak (11th May, 2020), tomo776 (10th December, 2019), willyboy28 (13th August, 2019), zeca (4th August, 2019)
    Jan 2016
    Quote Originally Posted by Catalizator View Post
    what you need virgin eeprom + program write eps
    what diagnostic interface do you use with this soft for reprog? just Clip?
    rafal's Avatar
    UK - PL
    need help
    now my goal is to buy xp-005
    who will help?
  8. The Following 3 Users Say Thank You to rafal For This Useful Post:
    brend (16th July, 2019), lobsterosxxx (16th July, 2019), serikpay (8th October, 2022)
  9. #7
    Dec 2018
    Quote Originally Posted by lobsterosxxx View Post
    yes
    , canclip
  10. The Following User Says Thank You to Catalizator For This Useful Post:
  11. #8
    Hello
    Please Renault modus Steering Fault
    DF002 Delete
    8200307151--A
  12. #9
    Oct 2018
    willyboy28
    test and report clear df002 cod for eeprom
    pass pm
  13. #10
    Dec 2018
    ......... no coment
  14. #11
    Nov 2018
    Cześć.
    Potrzebuję klucza ten eeprom dla Clio 3 8200294976A 50300685 LHD. Dzięki: spokojna :: spokojna :: spokojna:
  15. #12
    Aug 2018
    East Pole
    I have this Micra with the data below, from a friend of mine.
    K12F 2004 1475cc
    VIN: SJNFBAK12U1367246
    The engine starts ok, but the steering is running with no servomotor assistance. I don't have the car, only the steering column.
    Can you fix this dump? I also, don't have Clip or Renolink.
    I will try to attach dump and pic.
  16. #13
    baltazar3's Avatar
    Andromeda
    Quote Originally Posted by volorucinski View Post
    K12F 2004 1475cc
    Change (replace) steering column with good one.You dont have to reset code like Renault.
    '" live and learn........ if you wont ....you ain't "
    _______ . ____ . __ . __ . _______ . __ __ __ ... ---
    If my post was HELPFUL please push THANKS button
  17. #14
    Apr 2013
    I have also this same problem with my friend car. Modus 8200433517D 24c16 DF002. Please fix file. Thanks
  18. #15
    May 2013
    Hello. I have the same problem DF002 with my Clio 3. Can someone please fix my file? TRW Power Steering 8200 294 976 A (50300685LHD)
