Results 1 to 10 of 10
    Oct 2018
    Default Identify key bytes from Acura 2000 3.5 RL immo box dump
    The following is an immo box dump (not the ECU) from my Acura 2000 3.5RL (L46AR / 93c46). I am trying to identify the 4 bytes of each key that Zed-Bull uses to calculate the Megamos 13 transponder data. Can somebody point them out for me please?
    Also, can someone modify the dump to put it into learning mode? (Edit: this was a stupid question)
    Transponder Type: T5
    Dec 2018
    Minsk Belarus
    Quote Originally Posted by zairox View Post
    Why would you?EPROM is . learning key by dump.
    Oct 2018
    Quote Originally Posted by drrimz View Post
    After reading a looot more information I realized the second question was very stupid.
    This is what I have so far:
    Data for keys in dump:
    88 56 51 00
    88 56 C1 D9
    88 56 81 D2
    Is that correct?
    Dec 2018
    Minsk Belarus
    88 56 51 00
    88 56 C1 D9
    88 56 81 D2
    Is that correct?
    read Datasheet before reading memory
    reading 16 bit!??
    Oct 2018
    reading 16 bit!??
    Thank you for the hint.
    I did look at the datasheet and it says it is a 64 bit word x 16 E2PROM and that it is compatible with the instruction set of NM93CS46/56/66.
    If I read it as 8 bit, I get nonsense.
    I attempted to calculate the keys using the values I posted above and I get the following:
    FF 81 34 05 63 00 63 29 (88 56 51 00)
    FF 81 34 05 E3 D4 23 43 (88 56 C1 D9)
    FF 81 34 05 63 D9 23 3E (88 56 81 D2)
    But none of these match the transponder of the key that starts the vehicle.
    FF 81 C4 D8 94 F8 86 74 (this transponder works)
    I am aware I can clone it using Zed Bull and call it a day, but I want to be able to add and replace existing keys to the immo box.
    Can you give me more hints or point out what am I doing wrong?
    Oct 2018
    Never mind. After three days of nonstop reading and trial and error, I found a way to add pre-programmed keys to Megamos 13 dumps (at least for Acuras and Hondas) by making a small Java app that analyzes the hex data from the dumps and the transponder data string.
    It was so freaking simple, yet I had and incredibly difficult time finding anything in this forum that would indicate how to identify the values and their order from the dump, and I found nothing on how to manually calculate the transponder data from dump and vice-versa.
    I will later post the algorithm and a upa-usb script to extract, add, or replace new red, gray, and black keys in these vehicles so that newbies like me have an easier time fixing these immobilizers.
  7. The Following 3 Users Say Thank You to zairox For This Useful Post:
    apath_e (9th February, 2020), morgano (12th January, 2020), reham (11th February, 2020)
    Oct 2017
    Slovak republic
    Here you are
    alex_r_2001's Avatar
    New Jersey ,, USA
    For those I just use tango along with a t5 transponder ... At first was confusing but now simple ... That's a pretty cool app your making though I will be a great help for others that have not done them before...
  10. #9
    where can i get whatever utility you're using to display the keycodes from that dump?
    i've got a RL that came into my shop - owner just bought it and was told 'it just needs a new key'
    I want to make sure that the key i'm going to clone is actually in the immo box.. and for that matter, if it even has valid data in the immo box.. (the eeprom in the immo box looks like it has been messed with)
    Edit - This is a 'virgin' eeprom for this immo box....
    Red key - (28 79 76 2C) FF 81 04 00 CB 88 99 59
    Black key - (28 81 6C 7F) FF 81 C4 32 62 66 DE 1D
    Last edited by apath_e; 17th February, 2020 at 04:09 PM. Reason: Answered my own question through research
  11. #10
    Literally just found out the dump i pulled is a virgin dump for that immo box...
    Can anyone pull the red and black key 1 codes so I can make keys to now pair the immo box to the ecu?
