Hello everyone!
I have to replace the ECU of my Mazda 3, year 2003, 1.6 L gasoline. The one from my car is DENSO 279721-2240 and the ECU that I want to put in place is DENSO 279271-3990. Both ECU's are from the same type of engine (1.6 L , gasoline). Do you know if these two ECU's are compatible with each other? Can I safely make the swap?
The old ECU ( 279721-2240) has 93c56 EEPROM chipset (contains IMMO software) and the new ECU has S93A56 EEPROM chipset.
So, do anyone know if the IMMO code can be cloned from my old ECU to the new one?
Thank you!
