Results 1 to 15 of 28
    Jul 2018
    Default VDO CDR 500 disable code
    hello,
    I have VDO CDR500, I know the code for it, can somebody disable it in dump ? Customer wants radio will never request a code again.
    Code is 2165.
    Dump in attachment.
    Thanks.
  2. The Following User Says Thank You to subzverb For This Useful Post:
    smurkyface (31st January, 2022)
  3. #2
    momogsm's Avatar
    Just Say Momo, I Will Be Here. ��
    HI
    Code: 2165, Code OFF., SN: GM050031792813, Ver: 24469302
    IF I HELP YOU DO NOT FORGET TO CLICK ON THANKS AND REPUTATION
  4. The Following 6 Users Say Thank You to momogsm For This Useful Post:
    Decode Ghost (22nd July, 2019), KOMUTAN (19th March, 2022), low27 (14th June, 2024), masterskay62 (23rd July, 2019), smurkyface (30th January, 2022), wilczek75 (24th October, 2019)
  5. #3
    Decode Ghost's Avatar
    Aug 2015
    Quote Originally Posted by subzverb View Post
    hello,
    Code is 2165.
    Dump in attachment.
    Thanks.
    Hi code off dump............
  6. The Following 2 Users Say Thank You to Decode Ghost For This Useful Post:
    masterskay62 (23rd July, 2019), subzverb (23rd July, 2019)
  7. #4
    Jul 2018
    Quote Originally Posted by momogsm View Post
    HI
    so now I just need to flash this dump into 24C16 and radio will never ask code again ?
  8. #5
    momogsm's Avatar
    HI
    EXACTLY
    REPORT BACK
    THANKS
  9. The Following User Says Thank You to momogsm For This Useful Post:
  10. #6
    I do not know is it better to open a new theme or use one old with same question..
    I need code for following radio
    GM CDR500 (E) by VDO
    330886636
    no: 24 469 302
    Type: cdr500 (E)
    2F4
    Serial: GM050021563924
    dump in attach
    many thanks
  11. #7
    Dekster's Avatar
    Dec 2012
    POLAND
    Quote Originally Posted by joki_lo View Post
    330886636
    no: 24 469 302
    Type: cdr500 (E)
    2F4
    dump in attach
    many thanks
    .......... 4039
  12. The Following 3 Users Say Thank You to Dekster For This Useful Post:
    joki_lo (16th August, 2019), smoggy (16th August, 2019), Zann (16th August, 2019)
  13. #8
    wtf? you sleep here maaaaaan
    many thanks
  14. #9
    Mar 2020
    Finland
    Hi, please help, i replace the car battery and the radio locks, i don't know the code. If anyone knows where to get the code?
    VDO CDR500
    VDO 330886636
    Type : CDR500(E)
    No.: 93 171 870
    2F4
    GM050021304179
    Thanks in advance.
  15. #10
    Oct 2013
    Ukraine
    Quote Originally Posted by Sergovich View Post
    VDO CDR500
    VDO 330886636
    Type : CDR500(E)
    No.: 93 171 870
    2F4
    GM050021304179
    Thanks in advance.
    Hi, read eeprom 24c16 and post here
  16. The Following User Says Thank You to masterskay62 For This Useful Post:
    rafal (9th March, 2020)
  17. #11
    Mar 2020
    Finland
    Quote Originally Posted by masterskay62 View Post
    Help me if you can read it.
  18. #12
    rafal's Avatar
    UK - PL
    no no.................you need read eeprom by programmer m8
    need help
    now my goal is to buy xp-005
    who will help?
  19. #13
    Mar 2020
    Finland
    Quote Originally Posted by rafal View Post
    it's awkward but thanks.
  20. #14
    Newbie smurkyface's Avatar
    Jan 2022
    Once the code is turned off, will the radio work without entering the code at all? No checks, nothing? Even if the radio was hard locked by using up the 10 tries? And even after complete battery disconnect? :O
    Last edited by smurkyface; 31st January, 2022 at 09:10 PM. Reason: additional question
  21. #15
    Eeprom69
    Guest
    Hi.First you need to read eeprom 24c16 and set it up here and then the dump can be redesigned to be codeless and reset 10 erroneous attempts and all this will work as you stated!
  22. The Following 2 Users Say Thank You to Eeprom69 For This Useful Post:
    Decode Ghost (31st January, 2022), smurkyface (31st January, 2022)
