Results 1 to 12 of 12
    Default nissan qashqai fault codes
    Hi mates,
    I have 2 fault codes on 2016 nissan qashqai and i could not find out what is the problem,
    1.on ecu fault code U0111 lost communication with battery energy from LIN
    2.on abs fault code C1130 engine signal 1
    These codes appears 2 or 3 seconds after starting the engine.(battery and esp lamp goes on)
    Any idea how to solve this issue is much appreciated.
    Thanks in advance.
    Jun 2009
    Did you solve problem?
    Aug 2012
    got the same problems here on a 2015 qashqai j11 1.2 petrol. anyone find the issue
  4. The Following User Says Thank You to deutsch For This Useful Post:
    csaba73 (4th June, 2023)
    I've been scratching my head for days on this! Did any of the above solve this problem?
    replace alternator lin signal from alternator is your issue
    Feb 2013
    Lithuania
    Have same problem. After motor replace.. Where search the problem?
    Feb 2015
    has anyone solved this problem ??
    Jun 2023
    hungary
    Ugyanaz a probléma. Motorcsere után.. Hol keressük a problémát?
  10. #9
    Nov 2023
    Quote Originally Posted by matarelec View Post
    Hi mates,
    Thanks in advance.
    Hi, did you solve this issue.
    I have exact same problem with my Qashqai 1.6dci diesel. Have already repalced Battery and Alternator but keep getting same DTC. Anti slip light, engine check light, and battery light on. S/S, forward emergency braking not working.
    Car otherwise runs fine.
    Any guidance will be hugely appreciated.
  11. #10
    Mar 2020
    in the field
    The problem may be the DC-DC converter connected to the alternator lin,
  12. #11
    Jan 2012
    EU
    Hello!
    Can you please tell how did you solved this problem?
    I have Nissan Qashqai 1.2DIGT 2016, exactly same problem
    after 2-3second engine run -> dtc to ecu U0111-08 communication error
    also dtc in chassis control module and abs.
    charging light and esp comes on.
    - battery charge is ok when engine running > 14V
    - measured alternator LIN wire from ecu, there comes 12V to alternator, wire seems to be ok
    but no LIN communication in alternator while running
    - replaced alternator , no difference
    - measured LIN bus from dc-dc converter (behind glove box), in dc-dc converter there is LIN communication active while running.
    do you have good ideas what to test? / try?
    many thanks!
  13. #12
    Jan 2012
    EU
    Fixed:
    if you will have this U0111 / chassis control system error -fault after engine replaced ...
    -> check the connector/connection of the alternator (LIN-bus) according to the connection diagram and you will probably find the solution
    (the plug of the engine oil pressure sensor and the plug of the alternator can be mixed up)
