Results 1 to 2 of 2
    Default BMW MS40.1 flash
    Hi there,
    Im tryig to flash ecu 5WK9003 with SW from 002 to have it with immo off. Im using TL866 programmer but I cant write 002 sw to the flash. It always ends up with buffer error at 5C01. Ori file can be written just fine so the problem is probably in programmer settings?
    Does anybody have a suggestion?
    Thank you!
    Sapuhin's Avatar
    Feb 2017
    PL"Poland"
    Quote Originally Posted by BobbySD View Post
    Hi there,
    Thank you!
    try to use memory w27c512
    If I helped you - please press Thanks and REP.
    72 61 69 73 65 20 74 68 65 20 72 61 74 69 6E 67 20 69 66 20 68 65 6C 70 65 64
    I will help with all I can. Open for help 24/7 (Find software, dump, kick in the right direction)
    TECHSIX.NET - PLEASE BE CAREFUL THIS SCAMMER !!!!
