Results 1 to 11 of 11
Thread: VAG CAN PRO VCP
    May 2017
    Default VAG CAN PRO VCP
    Hi guys! I searched the forum but couldn't find something about the VCP. I intend to buy a VCP copy(5.5.1) but first I want to hear some reviews from other users. I need the VCP for eeprom read/write for some modules, pin code reading, some codings(I also use VCDS) and I want to know how good it works. Found copies from 25 to 50 euros, are there different qualities or is just the seller's profit? My biggest concern is about working without the risk of making any damage to the car I put it on.
    Dec 2014
    PL
    I used to read and delete error codes, read the measured values of the motor. I also use OCF, read pin code EDC 15 and 16, read mileage edc 15 and 16 ET.C. However, not all OCF functions work in VCP + K (5.5.1) For the coding and adaptation for me, VCD$ is better.
    There is little information on the internet about VCP.
    Read here.
    http://vcp.pl/
  3. The Following User Says Thank You to Mario6 For This Useful Post:
    teo21 (1st August, 2019)
    Dec 2014
    PL
    Feb 2018
    Can someone share the software 5.5.1?
    Dec 2014
    PL
    Here you have.
    Without dongle.
    VCP+K
    https://mega.nz/#!QFhlEJZB!UBT6fy-33...jsvOW7bdM3HztI
  7. The Following 15 Users Say Thank You to Mario6 For This Useful Post:
    Auto Sousa (2nd May, 2024), biela (28th April, 2022), dorcky (13th October, 2023), eFighter (2nd August, 2019), eliah (11th June, 2021), Gery (19th March, 2024), jacca (1st January, 2020), Joker22 (5th October, 2020), OoZz (20th September, 2019), RedNix (7th August, 2022), sebv2 (12th July, 2023), szymonzywiec (20th February, 2020), toninoxxx (3rd January, 2023), torzet (21st October, 2020)
  8. #6
    Sep 2016
    Consider it is worth to get for 25/50eur 1/8 or 1/4 orginal tool price with cutted funcionality. You have no support at all, no access to bugfixes, no access to zdc, no access to any reputable forum with hints.
  9. #7
    Dec 2014
    PL
    For a price of 10-20 dollars it is worth having it as a supplement to vcds. It is also worth due to the OCF functions. (although not all work)
  10. #8
    Jul 2013
    yorkshire
    If you want trouble free, get vcds, genuine. Good support, free updates.
  11. #9
    Sep 2016
    Quote Originally Posted by autoden View Post
    VCDS is unable to do important things from point where VAG ended with coding as only part of module configuration. It started around 2009.
  12. #10
    Feb 2016
    United Kingdom
    Just buy original one. It very very good tool. with full support and updates, all working functions, with zdc files library, etc. There are also plugins for EDC 16, EDC 17 flash, ESP Coding and VIM Manager. This tool is reasonably priced, you`ll get your money back very quickly.
    VCDS is completely different tool, it`s mainly optimized for diagnostics and coding only. VCP for more advanced jobs, retrofits, EEPROM access, etc.
  13. #11
    Feb 2018
    Can someone tell me if the MK60EC1 Coding works fine with the china clones?
