Results 1 to 7 of 7
    Dec 2016
    Default MPPS TRICORE HELP
    I have a china v18 and want to read a Siemens SID with TC1791.
    First i noticed that there is no CNF wire while Ktag uses it on the same ecu.
    Before getting the mpc id it warns me to make sure that the kline wire is connected to ignition pin.
    Which is not clear to me.
    Jul 2019
    Bulgarian , Montana
    807 or 208 you need read write?
    Dec 2016
    I am talking for this message.
    It is not clear to me what does it mean.
    Attachment 640850
    Jul 2019
    Bulgarian , Montana
    that ecu have cnf pls just tel what cars and sid you need read i post all pin and cnf omg...........just tel me sid 208 or what?
    Dec 2016
    I have the CNF pin from Ktag schematic but i do not know which wire from MPPS to connect.
    It is a Ford SID211.
    Jul 2019
    Bulgarian , Montana
    grean its cnf you cant read witch ktag clone or mpps that ecu mpps v18 ask you for pin and cant read the pin code from ecu! Only original kess , Autotuner or magx17 can read write that ecu
    But grean is ignation on ( CNF ) on mpps you need resistro 1000 om + 2700 om
    Dec 2016
    I guess the connection like Galletto
