Results 1 to 8 of 8
    Oct 2016
    Default Read Gateway Eeprom Dump with Programmer 4H0 907 468F Audi A8 2010 Help
    Am replacing a Dash on a 2010 Audi A8 4H Model.
    Old dash is displaying DEF and is powering on and off like as it likes.
    We have a second hand dash with same part number which has been Virginised with abrites.
    Old Dash part number: Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1 Part No SW: 4H0 920 910 D HW: 4H0 920 910 A
    Component: TDieGB------- H30 0297
    Revision: 26110011 Serial number: 658260810593016
    The next step i need to do is read the Eeprom Dump with a programmer as not been sucessful by OBD.
    Does anyone know which chip in gateway can bus module needs to be read or have a link or guide to do so.
    Or is there anyone local in uk close to bedfordshire who is willing to do this?
    Can gateway info below:
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 4H0 907 468 F HW: 4H0 907 468 C
    Component: J533--Gateway H08 0213
    Revision: -------- Serial number: 00000000037984
    Coding: 00CD077D00
    Shop #: WSC 02313 785 00200
    ASAM Dataset: EV_GatewUDS 001025
    ROD: EV_GatewUDS_AU57.rod
    VCID: 3461607E9FBE0DEA09-8060
    Voltage stabilizer:
    Subsystem 1 - Part No SW: 8K0 959 663 A HW: 8K0 959 663 A
    Component: J532_DCDCStab H16 0038
    Serial number: 10235000896011200180
    Many thanks
    Feb 2017
    Baltic
    easiest way would have been at dealer, in my area they ask like 40-50eur for this adaption. but dealer does not want to accept abrites virginized cluster.
  3. The Following User Says Thank You to mikkhh For This Useful Post:
    Usual Suspect (9th August, 2019)
    Oct 2016
    Quote Originally Posted by mikkhh View Post
    Already tried with Odis online. Car has been fitted with 5F control module with component protection of software so stops Odis test plan continuing.
    Hence why I need to do this.
    Oct 2016
    Anyone?
    Mar 2011
    Romania
    There is an eeprom near the proccesor of the can gateway , read that and use dump to set component protection with abrites .
  7. The Following User Says Thank You to mike870 For This Useful Post:
  8. #6
    Nov 2018
    P L
    CP in Gateway A8 4H0, is stored in the processor and eeprom. AVDI will not do this - accept the eeprom file from Gateway 4E0. If the cluster is logged out "Virgin State", Audi Dealer, ODIS Online also will not unlock CP - they do not have this option.
  9. The Following User Says Thank You to yarowsc For This Useful Post:
  10. #7
    Oct 2016
    Anyone got a guide of pin outs to read and what tool best suits this process
    many thanks
  11. #8
    Oct 2016
    Default Gateway File
    Hi can someone tell me if this gateway file has been read correctly.
    Abrites says invalid Configdump
    Was read from chip 25LC120E
    How can i attach it on here?
