Results 1 to 5 of 5
    Jun 2016
    Default Reading EDC16CP33 bdm100, ktag, kess on bench.
    Good morning guys,
    I got two units for data swap between them as one was faulty and car wasn't running properly showing internal eeprom fault.
    I've got kess, ktag and bdm100 - unfortunately Chinese copies.
    Haven't had any problems with reading any Bosch ECUs but 16cp33 drives me nuts. Can't connect it to the interfaces.
    Do they need any boot pin soldered or is there any other way to connect them? Could you please give some advice?
    I'm using frame plus special Bosch ECU adapters plus external power supply to the box. Software works on the computer, drivers correct.
    Thanks in advance for any help.
    Br
    Dec 2017
    Ktag on bdm Port Noe Problem my Clone read this Ecu Post picture of flault
    Jun 2016
    Test for EDC16+ from PSA - success
    Test for EDC16CP33 from renault - fail
    Both - BDM100 and K-tag.
    Dec 2017
    Try Protokoll p29 By k Tag
    See Here
    https://youtu.be/ne3sNk09a_w
    Jun 2016
    Tried that already. Still nothing.
