Ok so I know this isn't the normal heres my dump... PLZ BRO. I am playing with an Uno v3/MCP2515 module. I am noob when it comes to GMLan or Can-BUS. So far I got it to where I am reading it and I also think I have it sending. I am running at 33K3bts. I've been looking at the GMLAN_bible but I am just not sure exactly what I am looking at or looking for. So I am going to post the code. can someone please put a can message that will do something like set fuel level, RPM, MPH or Temp. I just want to make sure its sending correctly before really get down this rabbit hole. So instead of dump plz bro Im going to GMLAN plz bro.
Thanks in advance. I just want to prove to myself that this will work before I start my whole project. I want to make in the end something with a couple pots that will let you sweep gauges. I started with the 2007.5+ since its gm lan and easier to find data on instead of GM class 2. I also want to do one for the 03-07 later but one project at a time.Code:#include <SPI.h>#include <mcp2515.h> struct can_frame canMsg1; struct can_frame canMsg2; MCP2515 mcp2515(10); void setup() { canMsg1.can_id = 0x0F6; canMsg1.can_dlc = 8; canMsg1.data[0] = 0x8E; canMsg1.data[1] = 0x87; canMsg1.data[2] = 0x32; canMsg1.data[3] = 0xFA; canMsg1.data[4] = 0x26; canMsg1.data[5] = 0x8E; canMsg1.data[6] = 0xBE; canMsg1.data[7] = 0x86; canMsg2.can_id = 0x036; canMsg2.can_dlc = 8; canMsg2.data[0] = 0x0E; canMsg2.data[1] = 0x00; canMsg2.data[2] = 0x00; canMsg2.data[3] = 0x08; canMsg2.data[4] = 0x01; canMsg2.data[5] = 0x00; canMsg2.data[6] = 0x00; canMsg2.data[7] = 0xA0; while (!Serial); Serial.begin(115200); SPI.begin(); mcp2515.reset(); mcp2515.setBitrate(CAN_33KBPS, MCP_8MHZ); mcp2515.setNormalMode(); Serial.println("Example: Write to CAN"); } void loop() { mcp2515.sendMessage(&canMsg1); mcp2515.sendMessage(&canMsg2); Serial.println("Messages sent"); delay(1000); }
