    Aug 2019
    Default 9s12xeq384 Programming help
    Hi, I have a dashboard with the 9s12xeq384 Freescale/Motorola IC in with embedded eeprom. I see several tools that can read/write this via the canbus interface. I have searched around and can’t really find much on that chip other than a serial bootloader.
    Has anyone on here programmed these chips via the canbus?
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by Jack3885 View Post
    Dash...?
    What kind of dash...?
    Brand...?
    Model...?
    a little bit more information could be helpful...
    narkeleptk's Avatar
    May 2017
    USA
    I think I have read them with ori CARPROG but its hard to remember because when I do things by obd I don't tend to remember the mcu that is inside, only year/model of car.
    Xprog reads them with no issue through bdm, I know for sure.
    Aug 2019
    Erm not sure how to attract pictures but it’s the dash in a Ford fiesta st 2016 thanks for your reply
    Aug 2019
    Quote Originally Posted by narkeleptk View Post
    Ford Fiesta 2016? Might go with the xprog though, thank you
    narkeleptk's Avatar
    May 2017
    USA
    Ok, I take my original comment back then, don't think I had much luck on fiesta's with carprog. The mileage section might would connect but wasn't able to pull dump if my memory serves me right.
