Results 1 to 12 of 12
    Jun 2019
    Default 2011 vw jetta tdi
    I wanted to adjust the odometer with DigiPro3 clone.
    Everything was looking fine, but once the cluster restarted itself, it shows "error" instead of the mileage
    System description: KOMBI
    Software number: 5K0920971C
    Software version: 0204
    Hardware number: 5K0920971C
    Hardware version: H23
    Serial number:
    ODX name: EV_KombiUDSMM9RM10
    ODX version: A04203
    Long coding: 270F01
    Trouble codes:
    B200041 - Ctrl. module faulty
    Active
    Any suggestion how can I fix this?
    Thank you
    PETAR's Avatar
    hi friend i think for this dash is better use xtool
    Mar 2011
    Romania
    You need a checksum , or a good eeprom dump , save the immo data first .
    Jun 2019
    Quote Originally Posted by PETAR View Post
    Thank you, which version?
    Do you have a link?
    Jun 2019
    Quote Originally Posted by mike870 View Post
    Can you give me some details how to do that?
    What if I have a good eeprom dump, how can i write it back?
    Thank you
    Jul 2019
    Peru
    enviar la información para revisarlo,
    me pasó lo mismo, pero con otro modelo, es un error en el cálculo,
    Lo restauré con la COPIA DE SEGURIDAD ORIGINAL, lo intenté nuevamente y fue perfecto,
    GUARDE EL RESPALDO ORIGINAL, es importante
    esto evitará problemas
    Mar 2011
    Romania
    Quote Originally Posted by nemduma View Post
    Thank you
    It is best to do a eeprom back-up before try to change odometer with china tools , done the same mistake myself , look for one other dump from a good cluster and try to reprogram the immo data, or read the eeprom from your dash and pot it here maybe someone can fix it .
    Nov 2018
    P L
    this is how Chinese shit fixes counters. if you didn't do the back-up, you need a set. from the second counter (Nec and eeprom).
    Jun 2019
    Quote Originally Posted by yarowsc View Post
    While it is a chinese copy, it was working few times. I was just asking for knowledge if there is an easy fix in layman's terms.
    Nobody will invest in a very expensive tool for a simple thing like this, when a used, working, low mileage speedometer/cluster is around $50
    Jun 2019
    Thank you for your quick answer. I will have a second cluster soon, so I could have access to a dump. But how do I do? How i will write it back?
    Or how can I read the eeprom from me old dash(cluster/speedomter) ?
    Thank you
    Mar 2011
    Romania
    Thank you
    You need a tool that can read the immo data from the old dash ( mac , cs , pin , keys ) like abrites , smok , carprog or other and reprogram immo on new dash , don't forget to read and save the abs coding ...
    pepi's Avatar
    Find someone with with better tool , I use AVDI original and I had same problem when costumer came to me with error on dash . Just set new km value and AVDI will correct CKS. No need to replace dashboard.
    Sent from my SM-G975F using Tapatalk
