Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Mar 2018
    Default CPT UPA-S USB Pinout Help
    Hello guys
    Kia Picanto Airbag R7F701019
    R7F701019
    unit part no: 95910-G6010
    continental no: A2C97545802
    Someone know which pins correspond to this CPT diagram? for Upa-s
    Thank you
    EDIT:
    In case someone need pinout for this ecu for UPA>>>
    CPT-1 UPA-7
    CPT-2 UPA-9
    CPT-5 UPA-3
    CPT-6 UPA-2
    CPT-7 UPA-8
    CPT-8 UPA-6
    CPT-9 UPA-5
  2. The Following 8 Users Say Thank You to febianuy For This Useful Post:
    aroo84 (27th February, 2020), esse (4th August, 2023), julo45 (17th November, 2019), KADE007 (16th November, 2019), mscanii (11th September, 2020), Radek2000000 (14th November, 2019), rm23 (15th April, 2022), t-ortman (5th January, 2024)
  3. #2
    Mar 2017
    Colombia
    Hi mate, I don't think you can read Exe Module with Upa. Upa Still Doesn't Have That Family of Renesas RH850
    WINNER THE LOSER
    Mar 2018
    Quote Originally Posted by automotrizVIP View Post
    Yes if you contact upa support they will send you a test version which have new updates, which support this mcu
    Mar 2017
    Colombia
    Well, it was time for an update in upa....
    Sounds great
    WINNER THE LOSER
    Mar 2018
    Sounds great
    do you know the pinout friend?
    Uuprogs
    V2.1.0.00
    fixed bug SPC56AP54/60
    Added MB96F612/13/15
    Added RH850, R2C chips
    MB96Fxxx added unlocking flash memory by 16-byte key
    upD70F35* added 6MHz oscillator frequency
  7. The Following 2 Users Say Thank You to febianuy For This Useful Post:
    automotrizVIP (6th September, 2019), lwood (7th September, 2019)
  8. #6
    Mar 2017
    Colombia
    on other equipment Yes.
    Touch Look The Pin Out Will Use UPA-S, Then Compare If Equal to Other Teams, Sometimes All Teams Use Similar Solutions
    WINNER THE LOSER
  9. #7
    pedjica's Avatar
    Sep 2015
    Serbia
    Pinout cpt........................
  10. The Following 2 Users Say Thank You to pedjica For This Useful Post:
    aroo84 (27th February, 2020), rafal (7th September, 2019)
  11. #8
    Mar 2018
    Quote Originally Posted by pedjica View Post
    I attached this pinout when started the thread. I did not know the pins for UPA but i could make it. I added them un case someone needs it
  12. #9
    Tecdiag's Avatar
    Oct 2012
    Algeria
    hello all,
    please can someone help me to read this airbag ecu for kia 95910-G6010 with upa usb i follow the connection in cpt and it's seemes cpt1 and cpt6 is not connected on the cpt box and i didn't find the correct connection with upa usb .
    thx all for help
    If you can not fix it, please leave it as it cameIF I HELPED YOU PUSH THANKS AND REP BUTTONS
  13. #10
    Mar 2018
    Quote Originally Posted by Tecdiag View Post
    hello all,
    thx all for help
    In the first post i writed UPA pins... You need to connect at 3.3 to read/write correctly. no need external power
  14. #11
    Mar 2017
    Colombia
    In the New Betta Version. when reading RH850 read as you say @febianuy ...
    But when verifying it generates errors.
    Will it be that writing would look good?
    Reading: Success Device: R7F701019x Range: 0 - 7FFF
    Device Signature: 52 37 46 37 30 31 30 31 39 20
    Verifying: 2291 Errors Found Device: R7F701019x Range: 0 - 7FFF
    WINNER THE LOSER
  15. #12
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. After support from Mr. Penko ( elrasoft ) I got this info:
    All memory location that are in erase state will read random values.
    All memory locations that are not in erase state /consist real data/ will read correctly
    The same all the time
  16. #13
    castin's Avatar
    Oct 2015
    So ok, when You read random data from erase state, and load this random data back then bricked flash?
  17. #14
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. How it is made in other programmers like cpt for example? I olso think if I read random data and write back in ecu it is going to stop working.
  18. The Following User Says Thank You to PSAcars For This Useful Post:
    Felipevargas04 (24th January, 2020)
  19. #15
    amrif's Avatar
    EU
    always verification errors! Like SPC on honda sensors...
    Is this a beta version? Very weak UPA
    Why do they give something that doesn't work?
