Results 1 to 4 of 4
Thread: 2013 Ford KA
    Dunker's Avatar
    Yorkshire
    Default 2013 Ford KA
    Just a (hopefully) quick question. Ive got one of these in with a faulty body control - non runner. Customer has supplied a full ECU kit. Which I have swapped as per his instructions - vehicle now runs. The vehicle originally had 17801 miles on the clock. The new clocks have 45500 miles on them. What are my options here. Can I use the original clocks ?. Will this start the mileage flashing on the display if I use the original clocks ?. Can I just copy the mileage part of the dump from the old clocks to the new clocks, would this make mileage on display flash also ?. I do have a genuine FiCOM so I should be able to do proxy alignment - especially if its just a case of putting original clocks in and proxy aligning. Where is the mileage data stored in the dash, is it in the first 2 lines, I have a dump of the original 95080 so it should be case of just copying the data from 0x00 to 0x1F. I didn't want to just plug the original clocks in or copy any mileage data first without asking. OK, more than one question I know. Cheers.
    Thanks in advance.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  2. The Following User Says Thank You to Dunker For This Useful Post:
    Meat-Head (11th November, 2019)
  3. #2
    Dunker's Avatar
    Yorkshire
    Anyone? Will there be an issue just swapping the clocks?
  4. The Following User Says Thank You to Dunker For This Useful Post:
  5. #3
    Meat-Head's Avatar
    Sorry mate, missed this, the only time you really need help (4 a year) you dont get it.
    what was out come for reference
  6. #4
    put original clocks in then proxy aligned. fiat based. use multiecuscan
    or ficom.
