Results 1 to 13 of 13
Thread: Kubota RED keys
    Jul 2013
    Scotland. UK
    Default Kubota RED keys
    just been offered the job of cloning loads of RED keys for a national plant hire company. Apparently they get a Kubota tech to fly up from London to do them all red keys losts on these plant. £1000 a pop.
    I suggested cloning the red keys before they go missing. the black key here is 4D so assuming red keys will be too.
    Anyone seen transponder case blanks for this type key?
    anyone had success in cloning red keys?
    Pic of same type black key attached:
    Thank & rep for this who assist
    Essex/East London Boarder
    I had a plant hire company approach me in London for 15 spares buty they didnt get back to me .
    But my investgations lead me to belive you can Add Keys with the red master like other systems and the Blanks were an easy cross reference from another manufacturer .
    Bit Vauge but hope it helps a little .
  3. The Following User Says Thank You to Recoder For This Useful Post:
    instakeys (17th September, 2019)
    Jan 2017
    USA ����
    from what i remember the red keys are not used for anything but programming more keys
    i dont think they even start the damn things
    it is a literal programming key
    then the user keys are added with the red key
    if all lost ive seen the starter replaced matched with a set of keys\
  5. The Following User Says Thank You to sleepyrz For This Useful Post:
  6. #4
    scotland clydebank
    This sistem can be bypassed
    There is a video in your tube it takes less
    Than 5 minutes doing so
    Is ridiculous the price
    The charge for red key and programming 1000 pounds
    Two black keys this is not security
    Is a good way to make money for kubota plus there are problems as sometimes the red key will not be recognised and won't be able to reprogram black keys.
  7. The Following User Says Thank You to godfathertre For This Useful Post:
    Gumbo1976 (5th March, 2020)
  8. #5
    Jul 2013
    Scotland. UK
    Quote Originally Posted by Recoder View Post
    Your absolutely right, easy add black keys with red key. All machines keys are same, generic part. Lost all black and red keys is a nightmare.
  9. #6
    Jul 2013
    Scotland. UK
    Quote Originally Posted by sleepyrz View Post
    your also right, red keys don’t start them just a programmed black key. Not on excivators. Coded solenoids on fuel pump and hydraulics. Not easy to bypass.
  10. #7
    Jul 2013
    Scotland. UK
    Quote Originally Posted by godfathertre View Post
    Not a a five minute job...
    cant be bypassed by some guy off YouTube ?! Immobiliser cuts off fuel pump and hydraulics. Don’t post unless you know what your talking about.
    UPDATE to original post. There’s no way to get blanks for these, so found another original solution: got some other Kubota black key and drilled the rivets out to remove the transponder. (2 half’s of key case are held together with that rivet) installed a 4D carbon cloning chip and cloning did the job by looks of it. Will see when the plant guys will test them out. Waiting to see if code rolls on red keys after use. I’ll report what I find.
  11. The Following User Says Thank You to instakeys For This Useful Post:
    myteleco (21st March, 2023)
  12. #8
    scotland clydebank
    i have done this job on a kubota and i know what i am taking about .
  13. The Following User Says Thank You to godfathertre For This Useful Post:
  14. #9
    Mar 2020
    godfathetre wonder if you could help me out
  15. #10
    Jan 2021
    Take a look at this: https://ecu-repair.eu/brand/45-kubota
    perhaps they can solve your problem..
  16. #11
    Feb 2021
    Hi I have got a Kubota Kx015-4 and I have lost my keys, no red or black keys, is anyone here able to help me to get new keys??
  17. #12
    Feb 2021
    Hi I have lost my red and black keys for my Kubota, do you have a solution?
  18. #13
    Feb 2023
    hello!
    Im also trying to find the correct transponder, do you what type of transponder works on kubota u35? I think its 4d60 tx6f, but doesn't clone with red key. is it 40 or 80bits?
    thanks in advanced
