contact me pm. will help.
hello
here i attach perfect data
antonypaul (4th July, 2023), BusCan (31st March, 2024), electromech (14th September, 2024), radion360 (12th December, 2023), talk2idris (10th December, 2022), yarokas (21st September, 2020)
Hi could you please help looking for pinouts to read the jaguar 2013 front bcm
Thank you
Hello ,
Jaguar XF250 , NO KEY DETECTED , common problem when disconnectin the Battery
how can check these files from BCM Jaguar XF if correct , can read only eep + P-flash ,can't read D-flash with VVDI-Prog , when i try to read D-flash message Partition D-flash 0 sector 0K , eeprom 8 Sector 2K Check error
thanks in advance
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
Think this happened at local dealership when battery went flat
Car still started tho so assume KVM issue not BCM
Solidarity with Ukraine
in xprog you can select size of dflash manualy. try to choose mpc 9s12xe in vvdi, not bcm. maybe it will give you opportunity to select dflash size.
Dear Blink977, can you get in touch with me? E-mail gkalt83@gmail.com
Hello guys i need help i program Jaguar XF after battery dead and all working fine just steering lock cant reprogram still is locked , any solution ??
NO PASS
Can anyone help with this error whilst trying to programme front BCM? BCM Failed to write Target Identifier.jpg
Try this it might help ?
Plowman (4th January, 2021)
BCM Pin-out using vvdi prog
Thank You! :-)
I sincerely appreciate the real guys here that shared good information, i specially thank Topclef for the pin out too. I was able to read the dflash, eeprom and pflash from my module and recover the eeprom from the dflash. I however have more files and would need to remove the initial bits. I will find a away to do it and write back to car. This method i believe i dont need to use SDD again to programme the car?
Sent from iPhone 4S
topclef (9th January, 2021)
Reads from crank/no start car attached
