Page 5 of 16 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 236
  1. #61
    Top Poster ettaoussi's Avatar
    Aug 2012
    Please help repair file from bcm. DTC b102B key transponder U3002 indefication number. Lost keys after main battery disconnecting. I have eeprom dfash from BCM module end eeprom.
  2. #62
    topclef's Avatar
    Quote Originally Posted by ettaoussi View Post
    eeprom is ok , no need to repair it , the car has lost synchronisation between KVM , IPC and BCM
    if you have JLR SDD or AVDI you can do it by run immobilsation using SDD , or initialization modules using AVDI , all will be fine .
    you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
  3. The Following 2 Users Say Thank You to topclef For This Useful Post:
    BusCan (23rd April, 2024)
  4. #63
    Nov 2019
    Hi!
    I'm dealing with an XF JAG that won't start after a battery replacement (Key not present). I took the front BCM out because I was reading nonsense from it with the scanner. When I tried to read the EEPROM I get an EMPTY file. Is that ok?
    I have attached here the reading of the FLASH in case someone can help please
  5. #64
    Oct 2017
    Australia
    Upload your D Flash to see if EEPROM can be recovered from it
  6. #65
    Nov 2019
    Hi Paddjhon,
    The partition was corrupted so no D Flash either. I tried loading a virgin file but SDD wanted me to update the KVN to continue setting up the BCM. I don't have an account and I tried to buy one with no luck.
    I tried using the EEPROM from the back BCM. Not good. They are defenetly not the same.
    I also tried uploading another EEPROM just changing the VIN on it. I tried to do immobilization to sync everything. It failed. Then I tried to do configure existing BCM and it failed too.
    I'm running out of ideas. I also notice the instrument panel reports no keys programmed. Is that why the passive keys don't work either? This car was tampered with by 2 people before me so I'm not sure what's been done to it.
    Any help is more than appreciated!
  7. #66
    Oct 2017
    Australia
    You need virgin D Flash, P Flash and EEPROM and use SDD to program as new BCM.
  8. #67
    Nov 2019
    I have a virging P flash and EEPROM, but no D Flash. Maybe I didn't use the right virgin files. Do you have them?
  9. #68
    Nov 2019
    My other question. Is there a way to update the KVM and configure the new BCM without an online SDD account?
  10. #69
    Nov 2019
    I got the car stated! This is what I did in case it help anybody with the same issue:
    Create the partition EEPROM 2Kb (8 sectors) D-Flash 16kb (64 sectors). Load the virgin files to EEPRON and P-Flash (nothing to D-Flash). Open SDD go to "settings > system utilities > network options" and activate the network (with computer connected to internet). Then run the configure new BCM and follow instructions.
    After that the car starts but only with passive key. I'm still trying to figure out the keyless system. Any help is appreciated
  11. The Following 2 Users Say Thank You to masterfamp For This Useful Post:
    BeianM (25th March, 2025), electromech (14th September, 2024)
  12. #70
    Aug 2021
    Ciao 0n0t0le,
    mi chiamo Giuseppe e anche io ho il problema del bcm corrotto
    n° dx23-14B-476BG jaguar xf 2013 sportbrake.
    La storia è sempre la stessa, ho programmato come una nuova bcm e l'auto si avvia ma la lavatrice anteriore e il tergicristallo posteriore non funzionano.
    ho interrogato le centraline con sdd e il bcm è senza vin,
    leggendo i vostri post ho comprato al programmatore xprog 5.55 il problema e che non saprei come collegarlo e soprattutto come riscrivere la eeprom.
    Potreste aiutarmi dandomi istruzioni dettagliate su quali pinout vanno saldati sulla scheda bcm e come riscrivere la eeprom.IMG_20210815_095542.jpg
  13. #71
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by masterfamp View Post
    Surely just Add key service option in SDD. def try new battery and even try pushing unlock on key out of vehicle as I had hell of a job ie don't give up!
    New key coded straight away.
    PS. Did anybody share those virgin files
    Solidarity with Ukraine
  14. #72
    Sep 2020
    Quote Originally Posted by fred77 View Post
    May be u can buy new BCM from dealer , read it and share with all us ))
  15. #73
    Nov 2019
    Cool
    I ended up fixing everything. I had to put the keys on a programable state first. Then run an option to synchronize the modules. It asked me to add the keys and bingo! all working. Here are the virgin files I used
  16. The Following 34 Users Say Thank You to masterfamp For This Useful Post:
    adygopo (8th February, 2023), AGK (26th October, 2021), andye26 (27th June, 2024), askkey (18th August, 2021), AutoWOW (22nd May, 2023), BeianM (25th March, 2025), borysgo2 (19th June, 2024), BusCan (29th March, 2024), cjawahir (21st July, 2022), driiven (5th September, 2021), electromech (14th September, 2024), fred77 (15th March, 2023), haglund (15th December, 2022), Hayssam1 (16th March, 2025), jacek77 (28th December, 2022), key mechanic (11th February, 2023), khaledabdulaziz (2nd February, 2025), kokesek (24th March, 2024), kuru3coco (4th November, 2023), mkopytekchi89 (26th May, 2022), nawigorzow (15th September, 2021), obgoon (2nd January, 2024), Raptor181 (20th March, 2023), Shaman0777 (9th June, 2024), slavik (4th September, 2022), sogaro (29th September, 2021), stevan (21st February, 2025), techterr (24th February, 2022), tomasz2424 (2nd December, 2022), urcarpc (14th March, 2024), VincentV (7th January, 2023), vovan35 (19th May, 2022), wojtauek (18th August, 2023)
  17. #74
    ecumix's Avatar
    Apr 2014
    Default xf flat bcm front damaged after disconect baterry
    Hi can you help me with dflash from bcm jaguar i have the same problem .
  18. The Following User Says Thank You to ecumix For This Useful Post:
    serikpay (28th February, 2023)
  19. #75
    ypiter's Avatar
    Jan 2012
    RUSSIA
    Try dump...
  20. The Following 2 Users Say Thank You to ypiter For This Useful Post:
    ecumix (25th October, 2021), serikpay (28th February, 2023)
